The gases do curl under and very much. I think this is something you guys have to see, whether it is a CFD or real life example. But the exhaust gas will curl under in that type of setup.
An expanding flow has to go somewhere, and with a low pressure area immediately adjacent then some is going to leak in. That leakage will create a current that draws more in : this will inevitably create a vortex.
I may not know the language, nor the mathematics, but I understand enough about fluid dynamics to see how this happens.
Just because the flow in a region has one primary effect (e.g. separating the diffuser flow from the tyre wake), it doesn't mean that it won't have a secondary benefit. Aero within a regulated system is not an issue of singular effects : we aren't dealing with black and white here.
And what is the source of the heat causing the heat soak? The exhaust flow inside the diffuser?
There is no insulation on the surface facing the tire. Now this could be a misdirection, but it would seem like a majority of the exhaust heat does make it into the diffuser.
Could the vortex off the front of the tire contact patch be made to follow or be drawn in by the exhaust flow?
I still believe that the exhaust flow is effectively creating a larger diffuser wall on both sides. This combined with the high rake in effect is creating a much larger diffuser. In all my experience racing i cant see any other reason to run such a high amount of rake... you want the car as low to the track as possible and if the car is built properly there should be little to no rake. Red bull have effectively simulated a larger diffuser with exhaust gasses... Its a genius idea
without getting too technical, as the exhaust flow passes over the edge of the diffusor (the area where the cutout is and the exhaust is positioned) the pressure differential, caused by the low pressure of the fast moving expanding air inside the diffusor will then effectively suck the high pressure air at the edge of the diffusor inwards.
With the Exhaust flow passing over this area (Forgive me as i am not 100% and will do some CFD analysis after exams to try and get a definitive answer) Should disrupt the wake casued by the tire, effectively creating a sealed diffusor with the ground, causing the air inside the diffusor to expand without sucking in the turbulent air from the tires wake keeping flow attached, increasing efficiency and creating a higher pressure differential.
Bare in mind this is just a educated guess at the best
the wear pattern of the plank is visible a bit here
there is the leading edge outside corners scraping -the bip stay in the middle .so the outer sides getting pulled down at speed..
but were else is it actually touching the ground? It looks like almost in the rear half of the car...quite contradicting the perception the car has a lot of rake in it.
marcush. wrote:the wear pattern of the plank is visible a bit here
Absolutely nothing unusual here. The pattern of wear at extremities, is normal, due to height of kerbs etc.
trying not to be offensive here but in my experience skidmarks are rarely just starting somewhere in the middle of a flat face..but there you go.No need to elaborate further.
