I would have thought that with the better flow from the U shape side-pods that you would get more from efficiency from the rear wing and thus be able to run a smaller rear wing.
It just does not add up for me.
Brian
I did a study on this early in the thread. The drag is much much lower.beelsebob wrote:Yes.hardingfv32 wrote:For this discussion say the downforce levels are:
30% front wing
25% diffuser
30% rear wing
15% rest of the car/body
Now in Canada IF the McLaren rear wing was twice as bid as RB's, then that means they have to reduce the drag of some large amount on some other part of the car. Probably not the front wing because that would cause a big imbalance. I'm not sure there is much drag you can remove from the diffuser, so that leaves the rest of the body. You honestly thing the McLaren body has that much less drag to compensate for a rear wing that is twice as big?
Because you are adding when you should be subtracting!hardingfv32 wrote:I would have thought that with the better flow from the U shape side-pods that you would get more from efficiency from the rear wing and thus be able to run a smaller rear wing.
Brian
If this is true, how does Merc constantly nuke them for top speed with the same engine.beelsebob wrote:Sorry, I thought that would have more impact like that. To elaborate slightly...
In the dumb model... the amount of frontal area removed by the U-pods is significant – arguably as much as half the rear wing. In the more complex model, where they can direct air to wherever they chose (like straight into those U-pods), they likely save even more drag than that.
Pierce89 wrote:If this is true, how does Merc constantly nuke them for top speed with the same engine.beelsebob wrote:Sorry, I thought that would have more impact like that. To elaborate slightly...
I once asked a Minardi engineer why their car so often topped the speed trap but they weren't so good over a whole lap. The answer - "because we're missing a ton of downforce!"Pierce89 wrote:If this is true, how does Merc constantly nuke them for top speed with the same engine.beelsebob wrote:Sorry, I thought that would have more impact like that. To elaborate slightly...
Knowing McLaren it'll be delayed – I did hear this information pre-canada, so their plans may well have changed.Shrieker wrote:Big upgrade package for Valencia... Sounds to me like the wrong time. The race after that is Silverstone, the race which the exhasut blown effect will be banned (restricted?) by the FIA.
Nobody said it would be a diffuser upgrade.Shrieker wrote:Big upgrade package for Valencia... Sounds to me like the wrong time. The race after that is Silverstone, the race which the exhaust blown effect will be banned (restricted?) by the FIA.
I wasn't talking about lap time. I specifically mentioned top speed. The previous quote was about how little drag the Maclaren has. So I just asked why, if the Macca has so little drag, the Merc is quicker on top end. Speaking about drag only.Just_a_fan wrote:I once asked a Minardi engineer why their car so often topped the speed trap but they weren't so good over a whole lap. The answer - "because we're missing a ton of downforce!"Pierce89 wrote:If this is true, how does Merc constantly nuke them for top speed with the same engine.beelsebob wrote:Sorry, I thought that would have more impact like that. To elaborate slightly...
It's easy to be quick in a straight line; being quick in a straight line and in the corners is the tricky bit...
