Locked for further inspection.
Mind you that this is about the car, not its racing actions, nor the amount of points it got and certainly not about the MGP drivers.
Some posts might get deleted...
Yes the FIA uses stickers similar to 'void if removed' stickers in electronics.Caito wrote:
I want to have this posted, if possible: New to me, I've never noticed the FIA tag on the cover. Is with stickers how they enforce parc ferme?
Am I the only one that finds these obnoxious "Sutton" images akin to spamming?....wesley123 wrote:
New exhaust and also new cooling, ruins the whole tight sidepod
I'm with JET on this one, I think the old layout was better for the car, but the change was made due to the EBD off throttle blowing ban. But maybe not?Ferraripilot wrote:Finally a more efficient exhaust layout. As for the sidepods not being as 'tight' as someone mentioned, I actually would be the flow around these sidepods are considerably better than the prior units because the gills are removed. Still, I see what you mean I just see the removing of the gills as a huge huge plus.
vealio wrote:Now it happened what Ross said after the Barcelona test. If they see gains with the Red Bull solution in the windtunnel, they´ll adopt it.
