Rosberg lost one of the vertical diffuser vanes on one of the straights...Byronrhys wrote:
The vanes on the endplate finally arrive, the inner most blades of the diffuser and how the are formed are pretty interesting.
Byronrhys wrote: Has the rake increased to anyone else?
Well, the attention-to-detail from other teams in this area might well tell you otherwise. Why would you even bother shaping anything like this?n smikle wrote:The air velocity at that part of the car is almost zero.. so the covering is sort of inconsequential in the larger view of things.
Most likely the benefit of the EBD is huge compared to the reduction of air flow around the pipe. They will likely clean it up in the future if first they can without it melting, and second if it helps.munudeges wrote:Well, the attention-to-detail from other teams in this area might well tell you otherwise. Why would you even bother shaping anything like this?n smikle wrote:The air velocity at that part of the car is almost zero.. so the covering is sort of inconsequential in the larger view of things.
Nope! look at photo about 20 posts back. Different shape, different mountings.madly wrote:Is it W02s exhaust pipe?
Agreed. Heavy fuel loads in this car really throw it off. Solid 4th, maybe 3rd if Macca are having as a rough a time as they claimPredator wrote:
Rake seems to be the same as run in Silverstone. Race pace-wise, they're still fourth best. In the second sector they were losing up to a second, although I'm not sure if that is realistic as it could've been down to traffic etc.
