Thanks for the inputs.
Dave, I know that dampers are multifunctional, too. Thats why it called my attention that this guy (and the data acquisition companies that programs their softwares) pays attention to this type of graph that, too me, only seems to show how much time the dampers are working in each speed, wich is something that tells you nothing, for example, about transients.
It bugs me that they try to change damper "clicks" til they get a normal Gaussian curve for the whole lap instead of looking at particular cases.
Take for the example this track:
Here it only matters 1 y 2. The rest (3&4) are flat out. 3 includes a "left wheels" jump that will make the graphs look biased. Why would I look at "whole lap" data there?
On the other side, I have looked at those curves of lap record-breaking cars and they are almost Gaussian normal and in the same proportion at left and right car corners. Then, looking a badly tunned car I noticed the pattern doesnt follow Gauss.
What I intend to do with all this is to use the tool I can afford for now (damper sensors) for something else than looking at downforce, roll angle, dive, squat, etc. In otherwords I want to see if there is something more (like damper tunning) I can obtain from it.
