They produce a low pressure zone behind them, which helps drive the under wing flow around the tyre.MIKEY_! wrote:Those endplates still bother me... who decided presenting airflow with a perpendicular surface was a good idea?
Petroltorque wrote:Performance wise that guarantees they will be at the back and risk loosing touch with their main competitors.
When asked about relocating Willis in the BBC tried to not answer the question, I believe Spain and Epsilon is going to be the best option.ESPImperium wrote:Crude way of generating downforce, but seems to be working.
Id recon there will be another small update of this car remaining, but enough for a 0.2 of a second increase in pace.
Id recon the F112 is in full development now. Willis said there will be an announcement soon of what Hispania will do for 2012 in terms of resources and such. Personally i can see this team being relocated to a Spanish facility in its entirety with alot of new faces. Id recon a deal with Epsilon is on the offing with the new Hispania owners. HRT Epsilon-Cosworth anyone???
