The one which won Le Mans this year, to name just one.matt21 wrote:By the way, does anybody know if the are some liquid-cooled turbos out there?
And plenty others you can find under the bonnets of "regular" cars.
Yes but this would be a rather large resistor bank. Then you have to deal with the heat.matt21 wrote:
I think you can get rid of the excessive enrgy by transfering it to heat via a resistor.
Are you talking about the charge cooler? Water has a high specific heat, for all intents and purposes air to air intercoolers work better for petrol engines. Diesel engines are different, they don't use spark plugs they run off pure compression, a water intercooler will have a more stable temperature because of water's high specific heat. If you cool the intake charge too much you will lose power in a diesel.noname wrote:The one which won Le Mans this year, to name just one.matt21 wrote:By the way, does anybody know if the are some liquid-cooled turbos out there?
No, I am talking about water-cooled center body of the turbocharger. Water jacket is there to keep the heat generated by the turbine away from the bearings.godlameroso wrote:Are you talking about the charge cooler?
The MGUH will be directly feeding electricity to the MGUK (KERS motor) AFAIK. So under regular conditions the MGUH does not feed the ES (battery).flynfrog wrote:What happens when the pack is full?WhiteBlue wrote:If they use the MGUH to suck up all the excess turbine power and convert it to electricity they will not need a waste gate. At least not for any quantities of exhaust gas in a stationary state.ringo wrote:Then you have your waste gates to locate.
What if you are blowing the diffuser off throttle and the motor is in regen mode. A waste gate is such a small addition it doesn't make sense to rely on the electrics to do the job.WhiteBlue wrote: The MGUH will be directly feeding electricity to the MGUK (KERS motor) AFAIK. So under regular conditions the MGUH does not feed the ES (battery).
Blown diffusors will be a thing of the past from the end of the 2011 season. The teams agreed in summer to have the exhaust exit on the top side of the car from 2012 to make blown diffusors impossible.flynfrog wrote:What if you are blowing the diffuser off throttle and the motor is in regen mode. A waste gate is such a small addition it doesn't make sense to rely on the electrics to do the job.WhiteBlue wrote: The MGUH will be directly feeding electricity to the MGUK (KERS motor) AFAIK. So under regular conditions the MGUH does not feed the ES (battery).
also im pretty sure the battery and motor will be on a shared bus the power will go to what ever needs it.
WB - I think the question was if this will be allowed?WhiteBlue wrote:Blown diffusors will be a thing of the past from the end of the 2011 season. The teams agreed in summer to have the exhaust exit on the top side of the car from 2012 to make blown diffusors impossible.flynfrog wrote:What if you are blowing the diffuser off throttle and the motor is in regen mode. A waste gate is such a small addition it doesn't make sense to rely on the electrics to do the job.WhiteBlue wrote: The MGUH will be directly feeding electricity to the MGUK (KERS motor) AFAIK. So under regular conditions the MGUH does not feed the ES (battery).
Intercoolers were not allowed in CART, but I think it would be best located in the sidepod?WilliamsF1 wrote: ...
X - Where do you think will be a good place for a intercooler; indy porsche did not have a intercooler?
I think this is wrong.Pieoter wrote:BUT, there is no limit to the energy input by the MGUH (Apart from only being able to use ONE of the ERS systems to recharge the ES).
5.2.6 The ERS may only recover energy from the car via a single MGUK and/or a single MGUH.
ok blown wing then.WhiteBlue wrote:Blown diffusors will be a thing of the past from the end of the 2011 season. The teams agreed in summer to have the exhaust exit on the top side of the car from 2012 to make blown diffusors impossible.flynfrog wrote:What if you are blowing the diffuser off throttle and the motor is in regen mode. A waste gate is such a small addition it doesn't make sense to rely on the electrics to do the job.WhiteBlue wrote: The MGUH will be directly feeding electricity to the MGUK (KERS motor) AFAIK. So under regular conditions the MGUH does not feed the ES (battery).
