Having in mind that turbo charger therefore can't be placed in none of the sidepods, it becomes logical that it must be positioned along the cars center line. Same goes for inter-cooler, which as I'm suggesting would be placed on top of the FW33 flat style gearbox.
Compressed air would be delivered to cylinders by two slim manifolds at outer side of each cylinder block, while the exhaust manifold would obviously stand where on contemporary engines airbox and trumpets are.
I believe that it would be small increase of COG but more gained than lost on any conventional approach, allowing extremely slim sidepods that would virtually house nothing but radiators since compressed air manifold would be narrower than cylinder heads.
Air for inter-coolers would be supplied by split tunel within sidepods. The engine cover would be similar to RB7 big elliptical outlet, with post-turbo exhaust outlet within.
Now please, don't tell me that regs. don't allow switching sides of valve-train. [-o<
