Mclaren revival?
King of Spades
It's certainly not looking likely at the moment, is it... even if they are heavy. I guess we'll see tomorrow what their stategy looks like.
3rd year student, reading Aeronautical Engineering to Masters level at Loughborough University, UK.
A proud Maxthon user since 02-Oct-2005
מלך של עלהים
m3_lover
Looks like Mclaren have resort to a two plane front wing instead the usual three for the spanish GP.
Simon: Nils? You can close in now. Nils?
John McClane: [on the guard's phone] Attention! Attention! Nils is dead! I repeat, Nils is dead, ----head. So's his pal, and those four guys from the East German All-Stars, your boys at the bank? They're gonna be a little late.
Simon: [on the phone] John... in the back of the truck you're driving, there's $13 billon dollars worth in gold bullion. I wonder would a deal be out of the question?
John McClane: [on the phone] Yeah, I got a deal for you. Come out from that rock you're hiding under, and I'll drive this truck up your ass.
manchild
manchild
That car really looks mazing but its performance is awfull.
BTW, why isn't left upper wishbone cf black?
RH1300S
RH1300S
manchild wrote:That car really looks mazing but its performance is awfull.
Reinforced for that LOOOONG turn 3?
King of Spades
Perhaps it's just the way the Sun's rays are hitting it?
מלך של עלהים
janus
janus
if mclaren is better or..not we cant tell in monaco...in this race all the pack is closer ...but one thing i now ..to finish frist, you frist have to finish if the engine is +50hp and still blow what the point
JimmyK
JimmyK
Wasn't it said though that the McLaren would've lasted longer, cept for the fact that they weren't going fast enough to get enough cool air, thanks to the safety car.
tbh, Monaco can't be THAT one-off, imo, well, not in the case of McLaren, at least ;)
janus
janus
you are right about the coll air but the 22 cars don t have this problem.. and they have several position in the whell to regulate the engine it is easy do change de performance of the engine down ..and that way reduce the power and the need for a larger amount of air ..remenber in the last lap the drivers changes the engine preformance to save it...so mclarem or was a bad engine or kimi made a mistake???!! or was just bas luck
dumrick
dumrick
Why do you focus on engines that much? :P
Apparently, the overheating was on a heat shield that destroyed an wiring loom, which burnt... granted, two small fires in a weekend in the same car is a bit embarassing...
And that makes me wonder: McLaren seems to be the only one who uses real gold plated heatshields. Gold is apparently very good in that function. Or does this proves otherwise? :P
m3_lover
could be the fact, that since Kimi was all over Fernando, all he was doing was sucking in hot air into the car during all those laps, I think that was the main contributor to his engine fail.
Scuderia_Russ
m3_lover wrote:could be the fact, that since Kimi was all over Fernando, all he was doing was sucking in hot air into the car during all those laps, I think that was the main contributor to his engine fail.
Probably right. Same thing happened to Heidfeld when he was stuck behind Massa last year somewhere if I remember correctly.
"Whether you think you can or can't, either way you are right."
-Henry Ford-
wrk
m3, and the same for webber???
gentlemen start your engines......
dumrick
dumrick
IT WASN'T THE F***ING ENGINE!!!!!!
jgredline
if it looks like a duck, walks like a duck and quacks like a duck, its a duck.
To finish first, first you must finish.
vyselegend
But dumrick, from your point where did that heat come from?
I agree whith you that the engine didn't blow up, as we could see Kimi restart to park his car in the run off area after he stopped for the fire to be extincted by the marshal.
But the fact is the car went on fire, because the heat shield was saturated by the high temperature, which, excuse me, come obviously from an overheated engine.
Of course you can argue that there were enough reasons to explain it (slow speed behind the SC, Hot air behind the Renault, smaller radiators that hadn't been tested before...) but the fact is that the Mercedes engine overheated and appart Webber's Cosworth, other's didn't.
