Innovo 2012 F1 Car - Tozza Mazza and JordanGP
Tozza Mazza
Re: Innovo 2012 F1 Car
ringo wrote:what's the wheel base?
3330mm, plenty of room for the tank, engine and gearbox.
240
mine is at 3400mm.
I notice the diffuser has a valley where the the crash structure is.
Why not have it flat across the top?
Will the crash structure be that low?
jordangp
|The crash structure will be low in our design yes, as part of a design scheme to boost central downforce.
Tozza Mazza
jordangp wrote:|The crash structure will be low in our design yes, as part of a design scheme to boost central downforce.
yeah, minimizing the obstruction of the underside of the beam wing, and keeping CofG low, must be beneficial eh?
That shape is not final, but will be adapted to any changes of the diffuser roof, and could even be shaped to reduce drag/increase DF on the top of the diffuser, and the central part will be sculpted around the crash structure, it won't be that wide!
It's a bit of a valley atm :lol:
JimiJams
JimiJams
I love this project! I'll be waiting for more updates, Keep up the good work. =D>
"Leave me alone. I know what I’m doing" - Kimi Räikkönen
Tozza Mazza
Everything is taking too long!
Sidepods and engine cover are a complete nightmare to design, I just can't figure out how to make the two 'go together' in a nice way!
Thanks for all the support though!
Tozza Mazza wrote:Everything is taking too long!
Imagine what the manufacturing department has to go through. If I may Ferrari had a very interesting thing they did with the sidepods, it seems the philosophy was to improve aero within that region of bodywork(ie to influence flow through the sidepods openings), however their design compromised the way the engine cover tapers towards the rear. I think performance can be gained, but designing a nicely tapered engine cover can have a negative impact on through chassis airflow. Just another compromise to consider while you pull out your hair over the design.
Tozza Mazza
Cheers,
That's visible on F10, and by the looks of it, Renault had the same issue on the R30 aswell. It's just all this which turns my head to mush, I can't visualise it.
Its the transition from sidepod to engine cover, as it changes along the pod, along with intergrating the fuel tank into the design.
So confusing...
240
=D> :lol:
Muh hu ha ha ha. Yes they are a pain. Looking back it is easier to make a 1 piece car than making panels. I wasted a lot of time aligning panels for my design.
It's not worth doing piece by piece.
Do one big solid body, shell it, then cut it up if you wish.
Tangency is key though. When one curve ends and another begins, they need to be tangential. Also work with planes.
If you notice these:
The seams of engine and side pod are straight lines from top view. See the black lines?
It is easier to terminate the side pod in a plane and begin the engine cover in the same plane using the same sketch/curve as used in the sidepod.
hope this helps.
jordangp
A quick mock-up on the front of the car, and a preview of our work so far. Looking to launch the i12 on 12th/13th February, but still a long way to go. Suspension and Engine cover, the main areas needed to be done still.
astracrazy
astracrazy
31
looking good!
jakelewismclaren
jakelewismclaren
Re: Innovo 2012 F1 Car - Tozza Mazza
Really interested in this project, would love to do the same,, when is it going to be finished?
Come On McLaren
jordangp
Will be launched shortly. Sometime just after the 1st 2012 cars are released, can't confirm a definite date yet.
jordangp
Ok, we have a date :) The Innovo i12 Ford will launch on Saturday 28th January.
A preview from the 2012 noses thread:
jakelewismclaren
jakelewismclaren
i see that u have gone for the Duck Beak Nose
Come On McLaren
