Ferrari F2012
beelsebob
beelsebob
85
Re: Ferrari F2012
balalev wrote:
beelsebob wrote:Image
Your ferrari scaling is well off.
photos from different angles. sry
Huh? I'm comparing points on the same plane that have a known equal size. The wheels are different sizes, so you've scaled them wrong.
Raptor22
Raptor22
26
Re: Ferrari F2012
Redragon wrote:
Raptor22 wrote:arrow is pointing the wrong way for exhausts
I am afraid it is not, I can see the pipe pointing on this way on my screen
http://jorgelizalde.co.uk/ferrrari/Scre ... 30.532.png
Ah I see your convention. you arepointing the direction the exhaust gases are travelling.
I said to turn the arrow arond to point at the exhaust outlet. We are seeing the same thing.
Yes I agree, that is where the exhaust outlet is and the direction of gas flow.
That is going to have to change before the 1st test though so I believe we are not looking at the running bodywork. just a launch version.
A13EX_f
A13EX_f
Re: Ferrari F2012
the simplicity of the bump in the nose cone makes me think this is just a red herring and their actual race / testing nose will be much more complex, I mean even the caterahm's bump looks more developed than this one.
Raptor22
Raptor22
26
Re: Ferrari F2012
so you mean they have to crash test the actual race chassis before MOnday....
Redragon
19
Re: Ferrari F2012
ok first picture http://jorgelizalde.co.uk/ferrrari/Scre ... .59.53.png , sorry for quality but I just getting from slideshow.
And in this one I am showing my theory of two exhausts, engine pointing down center of diffuser and hot air from sidepods pointing brake ducts and rear wheels, sorry for poor english
http://jorgelizalde.co.uk/ferrrari/Scre ... .59.32.jpg
beelsebob
beelsebob
85
Re: Ferrari F2012
Raptor22 wrote:so you mean they have to crash test the actual race chassis before MOnday....
No, he means this isn't the one that's been crash tested.
ecapox
Re: Ferrari F2012
A13EX_f wrote:the simplicity of the bump in the nose cone makes me think this is just a red herring and their actual race / testing nose will be much more complex, I mean even the caterahm's bump looks more developed than this one.
Yep. I bet they show up with a better nose in testing. I bet thise one was just covered up for pictures. It looks like a brick in the wind.
NoDivergence
NoDivergence
50
Re: Ferrari F2012
So in other words, the car that we see here from driver's seat and up is not the actual car? Give me a break, you think they have time to waste resources on something like that?
beelsebob
beelsebob
85
Re: Ferrari F2012
NoDivergence wrote:So in other words, the car that we see here from driver's seat and up is not the actual car? Give me a break, you think they have time to waste resources on something like that?
Given that all it needs is the nose redone, and that is already a dummy part due to the overly simple front wing, yes, I do thin they'd waste resources on it.
King Six
King Six
Re: Ferrari F2012
No, just the changeable front wing assembly. Which includes the entire stepped bit and everything afterwards. The monocoque ends somewhere just after the suspension and then the removable nosecone starts, which can be completely changed/modified easily throughout the season.
The monocoque for this car is high, so they will still have to have a step in order to be legal, but the step might not be as crude as it is as the car is developed.
Gridlock
30
Re: Ferrari F2012
While it looks fairly blocky head on and from the side, this is largely due to the solid rosso colouring - if you look at a picture taken from a front-3/4 angle you can see the bump is sculpted into a U valley shape.
#58
Chasis_1992
Re: Ferrari F2012
zoro_f1
-2
Re: Ferrari F12
the most ugliest car ever!
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
shelly
shelly
136
Re: Ferrari F2012
Really the bump of the nose has a very little aero effect, just a local high pressure followed by low pressure and two weak vortices on the sides.
There are a lot of features in this car worth discussing, the bump even if it is a punch in the eye does not deserve much attention.
Front pull rod seemed impossible, or viable with compromises (tub extensions,hub extensions): here we see it done with an arm angle deemed unfeasible before.
The rear suspension has a peculiar arrangement too.
And then there is a lot of semiporisional bodywork, and original bits like the flapped pod wing
twitter: @armchair_aero
horse
Re: Ferrari F2012
shelly wrote:original bits like the flapped pod wing
Good spot! I take it you mean the turning vane being split, right? I hadn't seen that. I suspect we'll see a few more of these soon.
shelly wrote:Really the bump of the nose has a very little aero effect, just a local high pressure followed by low pressure and two weak vortices on the sides.
All of these bumps are going to suffer some drag, right? They are a little disadvantaged to McLaren in this respect, but I'd agree that it is probably not a great amount.
