Lurk wrote:Better to test if the front is correct before starting to test the middle and the rear. Otherwise how you would know - in case of a problem under the sidepods - if it is due to the sidepod or the front design.
Yeah great pictures to have a visual. Thanks you for posting. Air from the outer ends of the frontwing gets re-directed to the sidepods, w/o interferrence on anything else. Would have been great if they had applied red colored viz in the middle section of the front wing, which should show re-directing air under nose, passing around the sidepods on the floor.
Interresting enough there seems to be some of the green viz hitting the floor and certain sectiond just before the rear end...must be when directed over the sidepoods, getting pulled downwards...would be great to see a closer picture of the viz at the backend....
