Ian P. wrote:a boundary layer break over the top of the chasis
This?avatar wrote:yes, the "air dam" idea someone ran on CFD a few pages back looked pretty convincing for my money.
This isn't CFD, now, is it?n smikle wrote:Could it be an air dam?
Ansys eat your heart out!
]horse wrote:This?avatar wrote:yes, the "air dam" idea someone ran on CFD a few pages back looked pretty convincing for my money.
Why would you put energy into trying pushing air out of that slot into the oncomimng flow? Doesn't seem right to me. Or are you saying this can happen passively? Still don't believe it.
I think bleeding off the boundary layer might well be closer to the truth and I still think the Sauber solution is neater.
The difference between cold and hot is really the spark timing and fuel duty cycle not whether the throttle is CPU controlled or not. Teams can still use hot blowing or cold blowing. Just no multiple maps and no CPU throttle control after a certain rpm.Robbobnob wrote:
Cold Blowing is not Banned this year, only hot blowing by the regulation requiring the throttle to match the accelerator pedal.
Renault claim they used it back in 2009 for reliability and cooling. If any audio or a video of the Renault powered cars would be great!!
Although I have nothing to reply to your thoughts, i must applaud you for your nameAdrian Newby wrote:The air intake on the nose is far too large for its primary purpose to be "driver cooling".
And an "air dam" is the last thing he would want in that already narrowed area between the front tires (an air dam, and the air being redirected by it, wouldn't just go upward, but also outward).
I believe Adrian Newey is attempting to have the exact the opposite effect of an air dam. He is trying to get rid of any build up of air caused by this newly necessary hump in the nose by routing air through the bulkhead, past the driver, and out the cockpit opening.
You have to count the area "radiused in" to the hole/slot in the total. The new intake is quite a bit larger overall.Giblet wrote:Is it far too large? The old hole was a hole. This is a slot.
I subscribe to this idea. The air collected in the hole acts like a *bubble* of air, the allows external air to flow over it much more freely. The pressure might increase downforce, while not losing any "slippyness".murtoidf1 wrote: Looks like Ms Paint to me.. but someone mentioned the idea of the hollow point air rifle bullet. Sometimes a instead of a "aerodynamic" shape, a hollow instinctively draggy shape actually has a better reaction with the air flow.
Something to do with a boundary of air collecting around the hollow area almost acting as a buffer for other air and improving overall flow..
If that is the case, they could sculpt the nose to have a much less harsh angle on it, a la McLaren. I think it is something more than this.Adrian Newby wrote:The air intake on the nose is far too large for its primary purpose to be "driver cooling".
They only have a limited area (150mm?) to complete the transition from the nose to the chassis. Also, the "intake" section, by rule, must be into the chassis, not the nose. So it has to be at the bulkhead, not before.Hangaku wrote:If that is the case, they could sculpt the nose to have a much less harsh angle on it, a la McLaren. I think it is something more than this.Adrian Newby wrote:The air intake on the nose is far too large for its primary purpose to be "driver cooling".
Thanks!jordangp wrote:Although I have nothing to reply to your thoughts, i must applaud you for your nameAdrian Newby wrote:The air intake on the nose is far too large for its primary purpose to be "driver cooling".
I believe Adrian Newey is attempting to have the exact the opposite effect of an air dam. He is trying to get rid of any build up of air caused by this newly necessary hump in the nose by routing air through the bulkhead, past the driver, and out the cockpit opening.=D>
