You may be right, it's really impossible to tell from these shots for sure but it's fun to do a bit of speculating.Ferraripilot wrote:I think the low sidepod openings some are commenting regarding are an illusion. The head-on shot posted earlier clarifies the upper area of the sidepod to be in a traditional position.
To me it doesn't look like an optical illusion.
I'm going to put a wild theory out that the sidepods are actually divided into two sections utilising their double radiator arrangement which they were already using on the W02.So there's effectively 2 pods on each side with the larger wider sidepod containing one radiator sitting on a narrower sidepod with the 2nd radiator.
The openings may or may not be joined and this configuration will result in the pods taking on a shape similar to the McLaren U-pod but turned on it's side with there being an undercut as a result.
The top pod may even be shaped like the McLaren U-pods so there may be an uppercut and an undercut even.
