Williams FW34 Renault
joseff
Re: Williams FW34 Renault
boyracer94 wrote: The end of the mainplane looks interesting
An attempt to control tyre squirt?
RB7ate9
RB7ate9
In the Caterham thread, they had debuted a humongous exhaust cannon (basically a larger exit than the Red Bulls).
Considering that the FW34 has such an incredible drop off with the low gearbox, wouldn't it behoove them to have a similar exit out their engine cover? It might even smooth out the taper that they currently have (which isn't so much a taper than a pointed cylinder). Considering the volume and speed of the flow through the radiators, getting it wide across the beam wing would be ideal.
RB7ate9
RB7ate9
kilcoo316 wrote:
RB7ate9 wrote:Considering the volume and speed of the flow through the radiators, getting it wide across the beam wing would be ideal.
Nah, the smaller scale* turbulence kills the wing's ability to generate downforce.
*It'd be more medium scale coming from that monstrosity!
I figured as much in Caterham's case. I'll have to go back through the RB7 thread to read up about that cannon exhaust, since their's was often times pretty wide as well.
I wonder if Williams will try to change up where the radiator exhaust will exit? At the moment, it is blowing through the suspension much like most of the other teams. With that hobbit of a gearbox, there must be other potential change to the body work other than decreasing the volume down like that, though I can imagine it provides a pretty solid flow of air to the rear/beam wing.
roadie
39
Anyway, they had some issues today. Let's hope for a better one tomorrow, along with seeing what other new parts for Australia they have up their sleeve.
RB7ate9
RB7ate9
It appears low-speed handling is a major design point for the new car (apologies if a repeated post);
http://en.espnf1.com/williams/motorspor ... 71503.html
It may explain the rounded end, trying to allow as much air flow as possible for low-speed corners.
Jack Malone
Tomorrow the shall show more new parts.
Rear bodywork
RB7ate9
RB7ate9
:wtf:
Forza
238
Another top view
And one where you can see cooling openings by lower side of rear engine cover.
MIKEY_!
Little cooling exits (currently closed) in the front edge of the sidepods. I wonder why they gave up on the barrel exit they used last year. Liking the swirly top element on the FW.
roadie
39
Great photos guys, especially the combined overhead and rear view. I guess the position of the heat sensitive stickers shows the flow of the exhaust?
Yesterday wasn't fantastic and today doesn't seem to have gotten off to the best start. Let's hope things can improve!
Richard
Richard
Following several reports to the mods I've done a tidy up:
Team talk :arrow: viewtopic.php?f=1&t=12078&view=unread#unread
Wind tunnel & CFD :arrow: viewtopic.php?f=6&t=9868&view=unread#unread
Wings - drag v downforce :arrow: viewtopic.php?f=12&t=12115&view=unread#unread
As a pre-emptive note - Testing chatter belongs in the testing thread. :arrow: viewtopic.php?f=1&t=12073&view=unread#unread
If your comment isn't about an object that is on this car then it doesn't belong in this thread!
FW17
169
richard_leeds, what you have done makes no sense in the other threads
Dont you think this belongs here rather than the Correlation between CFD and wind tunnel results?
Blackout wrote:Old
New
Richard
Richard
ooops - Sometimes the moderator page defaults to select all posts, other times it doesn't, so it can catch me out. I've moved them back.
Please do click on "report post" if you see any others.
Sorry
