He maybe was reading the Ferrari thread here.bhallg2k wrote:I'm thinking the writer read something xtraordinary on the Internet and just ran with it.
Inboard suspension pickups.Crucial_Xtreme wrote:Can a suspension guy answer what is the proper name of where the wishbones attach to the chassis? Not a big suspension guy..
Crucial_Xtreme wrote:Ok here is the article from AutoSprint about the Ferrari F2012 front pull rod suspension. Honestly it's much like the free article posted on their site this morning but in the interest of fairness & being objective, I post it here to be discussed. Even if Xpensive will try and tell me he told me so. But obviously it's speculation and we'll find out in Spain or during the Mugello tests which come first.
AutoSprint Ferrari F2012 Front Pull-Rod Suspension Analysis:
Does the front pull-rod suspension flex the body?
In Ferrari all of the team knows that they have to do lots of work to fight for the first positions. At this moment the F2012 has a little window where it's competitive.
We all know what are the problems: no traction in slow corners and low top speed. But the question is: why?
Lots of "trusted" rumors (from engineers that work in other team) say that the origin of the problem is the front pull-rod suspension which, according to the team, doens't create any troubles.
Objectively the geometry of the suspension is a bit strange: chassis high with an horizontal rod... How can it work fine? So, according to these "experts", the big forces generated during braking or acceleration can flex the chassis where there are the attachments(wishbones) of the suspension attach to the chassis.
But a chassis has to be light and RIGID.
This would be an inexpicable mistake: this is studied in the first year of University. It's impossible that in Ferrari the engineers haven't considered the problem of this kind of geometry which also makes the setup changes more difficult.
The pull-rod generates less drag but the F2012 hasn't a great top speed so what do they have to do?
Ferrari has denied that they are going to reintroduce push rod suspension on the front but it is quite certainly that the only change of the exhausts system won't be enough to have the same performance of the other teams. But maybe in this way they could find the balance between the rear and the front.
Large high res image of the article--> http://img825.imageshack.us/img825/4859 ... df2012.png
Thanks to F1 Technical member Italian for help with the translation.
Also of note member Scarbs has said he believes the front pull rod is fine and is not the cause of the F2012's problems.
@bettonracing thanks!!
In fact the A-arms are connected to the chassis via so called "flextures" which are actually solid titanium pieces.bettonracing wrote:Inboard suspension pickups.Crucial_Xtreme wrote:Can a suspension guy answer what is the proper name of where the wishbones attach to the chassis? Not a big suspension guy..
I remember seeing this a while back and thinking it was unusual:timbo wrote:In fact the A-arms are connected to the chassis via so called "flextures" which are actually solid titanium pieces.
Well, it's no surprise to me that they might well admit something privately that they don't want to publicly. Time will tell on that point. I would imagine that engineers in other teams will be baffled.Translated Autosprint wrote:Lots of "trusted" rumors (from engineers that work in other team) say that the origin of the problem is the front pull-rod suspension which, according to the team, doens't create any troubles.
Yep, that's exactly what a lot of people have been wondering.Objectively the geometry of the suspension is a bit strange: chassis high with an horizontal rod... How can it work fine?
Well, to my mind they are basically saying that there are vastly increased forces involved in this suspension geometry and they are having a very strange effect, which we've kind of suspected. I know lots of people have been quick to point out that this geometry presents no problem but I just don't see it. A horizontal pull-rod like that is going to put a lot of stress on itself and probably the wishbones as it struggles to get the required movement. On a very basic level I don't see many strong, rigid and compliant triangular structures in this layout.So, according to these "experts", the big forces generated during braking or acceleration can flex the chassis where there are the attachments(wishbones) of the suspension attach to the chassis.
That's pretty strong criticism, but there must have been some central reason why they came up with this and I would dearly like to know what it might have been.This would be an inexpicable mistake: this is studied in the first year of University. It's impossible that in Ferrari the engineers haven't considered the problem of this kind of geometry which also makes the setup changes more difficult.
I think it's a given it will happen sooner rather than later. More than anything else if Ferrari are to develop then they need to move on from a known point with something they are familiar with. What they have is a journey into the unknown for seemingly little to no benefit. You can't do a lot aerodynamically if the mechanicals are a (possible) moving target.Ferrari has denied that they are going to reintroduce push rod suspension on the front but it is quite certainly that the only change of the exhausts system won't be enough to have the same performance of the other teams.
