Ferrari F2012
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Tobi1315 wrote:
Crucial_Xtreme wrote:
Tobi1315 wrote:why cant i see my posts?! there is a big delay from when i post to when they come up? im new to this forum.
I have two great photos that work in "preview" I want to submit..
From the pictures I saw today, Ferrari didn't have the gills installed on top of the side pods close to the driver. As for the lateral wing, that may very well be a possibility.
Yeah, I also saw that picture, but look at my post above, very much looks like grills to me!
You're right. They are on one car & not the other. Good spot. I think that might happen with the new engine cover too. They're doing it with the FW too. If you look at Mazdaboys post on page 206 at the end of one post & beginning of another are both versions of FW
Tobi1315
Tobi1315
Re: Ferrari F2012
blokkie wrote:
richard_leeds wrote:Our spam filter was tightened up recently. It worked, but now has a few false positives were genuine posts are caught.
Fortunately they go to a holding place for moderator attention so they are not lost.
I've been in PM contact with Tobi to resolve this.
Our mods Rule !!
Thx for the feedback richard !
Now back on-topic :)
Yep! Great forum and fast support, been following F1 for the last 10 years and always been interested in the technical side of thing, just didnt know forums like this existed, until now that is :D
f1316
f1316
80
Re: Ferrari F2012
Crucial_Xtreme wrote: You're right. They are on one car & not the other. Good spot. I think that might happen with the new engine cover too. They're doing it with the FW too. If you look at Mazdaboys post on page 206 at the end of one post & beginning of another are both versions of FW
As I said earlier, Red Bull have confirmed they are running different exhaust configurations on each car in first practice, and it certainly looks likely that Ferrari might do something similar (that is, try different specs with different drivers, not necessarily anything to do with the exhaust).
PistoneRovente
PistoneRovente
Re: Ferrari F2012
I'm pretty sure the gills/grills were there already in Sepang
http://www.google.co.uk/imgres?imgurl=h ... EwAg&dur=1
f1316
f1316
80
Re: Ferrari F2012
So, actually, to continue you that thought, what might the two configs be?
It might appear as if one will be in complete Malaysia spec and the other will have all of the below new components:
New engine cover/cooling exit
Lateral wings (or the beginnings thereof)
New front wing (correct me if I'm wrong, but we're just talking about new end plates here)
Anything else? Is there merit to this accumaltive approach? Or, does it make more sense to try a "base" car - say, in Malaysia setup - and then trial each new component seperately? Or, in fact, is it likely that these three, and other, updates have to be used in conjunction?
Many questions and speculations, I know.
Tobi1315
Tobi1315
Re: Ferrari F2012
PistoneRovente wrote:
Tobi1315 wrote:
Crucial_Xtreme wrote: From the pictures I saw today, Ferrari didn't have the gills installed on top of the side pods close to the driver. As for the lateral wing, that may very well be a possibility.
You are right! but did they run them in the race or just practice?
PistoneRovente
PistoneRovente
Re: Ferrari F2012
http://www.google.co.uk/imgres?imgurl=h ... EwAg&dur=1[/quote]
You are right! but did they run them in the race or just practice?[/quote]
Looks like they run it all week end in Sepang
http://www.formula1.com/gallery/race/20 ... riday.html
http://www.formula1.com/gallery/race/20 ... urday.html
http://www.formula1.com/gallery/race/20 ... unday.html
bhall
bhall
244
Re: Ferrari F2012
I nicked this from the C31 thread.
madly wrote:Image
That, my friends, is what Ferrari meant to do. (Well, you know what I mean.)
EDIT: I think I could stare at these pictures for an hour, given all the time I've looked at those stupid Acer ducts.
banibhusan
Re: Ferrari F2012
These are the things that will be new in the Ferrari, at least as of now:
1) New engine cover with cooling adjustments, more like Sauber's. And rumours are that they have made some changes in the radiator packaging for this new cooling solution. But no one has confirmed it yet.
2) New winglets just behind the mirror and the single winglet seen in Aus and Malaysia are removed.
3) Rear suspension tweaks.
4) Modified FW element.
5) New brake duct turning vanes.
Add to the list if you come across anything suspicious. 8)
Edit: Did I miss the hypothetical "Bryne floor"?? Let it be, it's anyways hypothetical.
amouzouris
105
Re: Ferrari F2012
banibhusan wrote:These are the things that will be new in the Ferrari, at least as of now:
where are the updates confirmed?? rear suspension modified to cope with the lower rear right height (i.e. less rake)??
volarchico
volarchico
Re: Ferrari F2012
Mazdaboy wrote:
Oh man, those reflections went and sprouted little wings! And if all the speculation comes true, one day they will grow up to be big Sauber-wings.
But more seriously, what's the point of having a wing directly behind the other? You would think the first one would create the necessary aerodynamic effect and the second would be blanked out by the first.
EDIT: Nevermind...after looking closer these don't appear to be really for vortex generation, but instead to help turn the flow over the sidepod sort of like a slat of an airplane wing. And actually, it seems they would be generating some lift, not downforce.
amouzouris
105
Re: Ferrari F2012
its shape is designed to create lift ..yes..BUT..the leading edge is angled downwards so i would guess that it neglects the lift of the shape...i think they are there for flow conditioning..
volarchico
volarchico
Re: Ferrari F2012
It's all about local flow angle though. Though the leading edge is angled down, I'd have thought the local flow in that region was coming from low-to-high into/over the sidepod. So perhaps they are just flow conditioners aligned with the local flow to help it turn over the top of the sidepod.
gray41
Re: Ferrari F2012
Mazdaboy wrote:[
Anyone think these could eventually join up the the split barge boards making two wings?
also is this even allowed, they'll all start sprouting wings all over at this rate.
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
bhall
bhall
244
Re: Ferrari F2012
Mr.G wrote:Borowed from sauber tread. Could be the new two winglets extended and go to the sides like it is in here?
That may not be necessary*. If you look at the Ferrari mirrors in comparison to those found on the Sauber, it's possible their placement has much the same effect as Sauber's horizontal element over the sidepod.
Since mirrors are required, it makes sense to mitigate that mandatory drag by putting them to use in as many ways as possible. Using them as flow conditioners follows that logic. The Red Bull mirrors are very much the same way, and they also don't have a full element over the sidepod.
* Obviously, nothing is certain.
