Interesting indents now in the gurney above the diffuser and it seems (to my old eyes anyway) that the gurney on the sides is "shallower" so perhaps they are looking for more flow there now???Crucial_Xtreme wrote:Comparison, old & new
Center of PR0n?Nando wrote:CoP you mean?Postmoe wrote:Perhaps the new diffuser/beam wing/exhausts are giving better aero COG.
.poz wrote:Any pic of the rake of the car ?
Postmoe wrote:.poz wrote:Any pic of the rake of the car ?
If you look at the crucial comparison you'll see there's a massive change in rake terms. The new one has such a radical approach that it even look like it is floating.
Incredible indeed.
You forgot thePostmoe wrote:.poz wrote:Any pic of the rake of the car ?
Incredible indeed.
difference in height between front and rear end of the carTeechnical wrote:What exactly does Rake mean?
Low front ride height and high rear ride height is a lot of rake.Teechnical wrote:Postmoe wrote:.poz wrote:Any pic of the rake of the car ?
Incredible indeed.
It means how the car is angled from front to rear. Last year`s exhaust blown diffusor allowed to run a higher angle of the car, the rear had a higher ride height. An angled car produces more downforce, if one can manage to seal the sides of the diffusor properly.Teechnical wrote:Postmoe wrote:.poz wrote:Any pic of the rake of the car ?
Incredible indeed.
If you talk about aero balance i think the correct term is Center of Pressure.Postmoe wrote:Center of PR0n?
I don't know I was refering to the aerodynamic equilibrium between axes and all the stuff, that normally has it own logics in comparison to mechanic CoG.
I fear I don't know the exact term so I put aerodynamic and CoG together in order to create an inbreded one.
Yes, yes. That's how it works. It's completely passive, the driver is doing nothing so it's legal.ForMuLaOne wrote:It means how the car is angled from front to rear. Last year`s exhaust blown diffusor allowed to run a higher angle of the car, the rear had a higher ride height. An angled car produces more downforce, if one can manage to seal the sides of the diffusor properly.Teechnical wrote:Postmoe wrote:
Incredible indeed.
@postmoe: In the picture you are reffering to, the car does not touch the ground. It is jacked up.
Yes, it has more sense since there's no gravity involved. I just forgot it was pressure, and I will forget it another time. I always forget these sort of thingsNando wrote:If you talk about aero balance i think the correct term is Center of Pressure.Postmoe wrote:Center of PR0n?
versus Center of Mass (or Center of Gravity) for the actual weight distribution on the car.
