There's a chance of rain but should almost certainly be cooler.banibhusan wrote:Not sure about showers, but drivers in the interviews said that temp would be much cooler than today.Teechnical wrote:Are showers expected tomorrow at Montmelo?
What really was suspicious was how they maniouvre to give excuses at the end to the press?beelsebob wrote:Exactly my point – no one sane in that position would take that risk... Thus, the likelihood is that them taking that risk is not the explanation... Instead, they may genuinely have had warnings come up about the car... They may genuinely have misscalculated the amount of fuel burn... They may all kinds of other things.Redragon wrote:So it is so clear the advantage, why they took the risk for second time?
Predictions of weather are usually wrong at the GP... apparently it'll be 21c.banibhusan wrote:Not sure about showers, but drivers in the interviews said that temp would be much cooler than today.Teechnical wrote:Are showers expected tomorrow at Montmelo?
I thought this had become apparent to everyone already. Hmm...foxmulder_ms wrote:...
Also, I want to point out tires are dangerously becoming too dominant of a factor, taking out of race excitement.
i thought it was in the last sector but i'm not sure.Unc1e_M0nty wrote: If they can prove this the stewards can let them off.
Whitmarsh is quoted as saying 1.3l would have got him back to the pits with a litre to spare, doesn't sound enough to me, where did he stop - haw far was he away from the pits.
And if temperatures are significantly lower tomorrow (21c) it could be quite a race.Mestrades wrote:Okey, let's compare the FP3 "full tank" stint of Rosberg, with the "full tank" stints of FP2 yesterday.
[img]http://img855.imageshack.us/img855/6267/stints.png[img]
Uploaded with ImageShack.us
Y coord: lap time - 60 seconds
X coord: # of the lap
It has been the best stint of the weekend. Obviously, we don't know the load of fuel
He stopped just before turn 9, about half way through the lap. At racing speed you need about 2 litres to complete a lap, so the question is, do these cars burn 1 third the amount at a coast... I can believe that they probably do once you've disabled a few cylinders, and run the engine leaner.Unc1e_M0nty wrote:beelsebob wrote:Exactly my point – no one sane in that position would take that risk... Thus, the likelihood is that them taking that risk is not the explanation... Instead, they may genuinely have had warnings come up about the car... They may genuinely have misscalculated the amount of fuel burn... They may all kinds of other things.Redragon wrote:So it is so clear the advantage, why they took the risk for second time?
I think it's just poor management of the situation by McLaren rather than an indication of anything deliberate.Redragon wrote:What really was suspicious was how they maniouvre to give excuses at the end to the press?
One of the engeniers coming to talk to Hamilton after weight procedure.
Too secretive to be just a failure
Or it is what I felt watching it
2 liters? No way. It's likely something between 3-4 liters.beelsebob wrote:At racing speed you need about 2 litres to complete a lap,[...]
I am getting confused now, I thought your argument to believe that Mclaren didn't get the risk of running with low fuel was,MrBlacky wrote:2 liters? No way. It's likely something between 3-4 liters.beelsebob wrote:At racing speed you need about 2 litres to complete a lap,[...]
