With the new Exhaust, what concept will they go with, revised "Spud Cannon" exhaust.
Revised Acer Duct Exhaust...yuck
Or could they be going into the realm of the Barcelona spec exhaust that Lotus had? (deep inset of rear sidepod).
+1Vanja #66 wrote:Scuderia has Hamashima, Alonso said that they understand tires quite well...
elFranZ wrote:Fuel tank breather, mistery solved
Yes I'm aware of that mate but they specifically mention modifying radiators & outlet to reduce drag & help top speed which they imply will also come with change of position.amouzouris wrote:yes but internal fluid dynamics does not mean that they will change they radiator layout..the might change it..they might not.. i think it has to do with where the hot radiator gases are routed to...and probably make it easier for the gases to flow to gain some top speed...
oh ok mate! i thought they didn't mention change in radiator layout...Crucial_Xtreme wrote:Yes I'm aware of that mate but they specifically mention modifying radiators & outlet to reduce drag & help top speed which they imply will also come with change of position.amouzouris wrote:yes but internal fluid dynamics does not mean that they will change they radiator layout..the might change it..they might not.. i think it has to do with where the hot radiator gases are routed to...and probably make it easier for the gases to flow to gain some top speed...
Edit: They also mention modifications to the suspension for Monaco to help with turning radius, etc
Of course, I just threw in that extra bit to get X going...amouzouris wrote: oh ok mate! i thought they didn't mention change in radiator layout...
suspension changes for monaco are expected..they do that every year
