McLaren Adjustable Brake Duct
hardingfv32
hardingfv32
35
scarbs wrote:
(This is) an adjuster for the brake duct opening around the disc. This sends more heat to the wheel and hence into the tyre. The team use it to alter rear tyre temp over the weekend , presumably in the race too!
1) How does heat from the disc get to the inside half of the rim with these fully enclosed brake housings?
2) This looks like a duct adding air flow after the disc exhausts. Why? Am I correct to assume disc cooling flow is always inside to outside?
Brian
strad
117
Re: McLaren Adjustable Brake Duct
I think that when dealing with temps like the brakes reach, it can't help but radiate to the tire.
Sir Stirling Moss
hardingfv32
hardingfv32
35
Could the duct in the lower photo be a brake cooling flow bypass route?
Brian
mbb72
mbb72
-1
mclaren adjustable brakeduct
Hi all I'm a new member hoping someone can confirm if mclaren are using their adjustable brakeduct to control tyre temperature. Everything i have seen/read left me with the impression it may be mainly used for something else, with a secondry benefit to tyre temperature.
Reason: merged into existing brakeduct discussion.
mbb72
mbb72
-1
http://scarbsf1.wordpress.com/2012/05/1 ... ake-ducts/
I found this the other day which offers brief description of how it works
