scarbs wrote:
(This is) an adjuster for the brake duct opening around the disc. This sends more heat to the wheel and hence into the tyre. The team use it to alter rear tyre temp over the weekend , presumably in the race too!
1) How does heat from the disc get to the inside half of the rim with these fully enclosed brake housings?
2) This looks like a duct adding air flow after the disc exhausts. Why? Am I correct to assume disc cooling flow is always inside to outside?
Brian
