Original High-Res
I also think there are changes to the floor in the diffuser area, adjacent to the rear tires. If you look close in the photo you attached you can see the blue paint from the ground visible to the right of the rear tire. There appears to be a cut out in the edge of the diffuser/floor where I assume they are trying to allow the exhaust to pass under the floor and into the diffuser. What this there before and I just never noticed?
It may be a little different, but not sure. Need to look at more pictures. Here's one from Canada and you can see there's a gap there. Will look at more to see how much it's changed if at all.f300v10 wrote:
I think the slot is the same, I just didn't notice it when they ran it in Canada.Crucial_Xtreme wrote:It may be a little different, but not sure. Need to look at more pictures. Here's one from Canada and you can see there's a gap there. Will look at more to see how much it's changed if at all.f300v10 wrote:
Its a straight line test so i cant be anywhereDream Theater wrote:During the race, the Italian RAI TV commentators said that some engineers and mechanics of the Scuderia Ferrari will not come back to Maranello, because the next week they will test with Marc Genè some new components for Silverstone and Hockenheim. I only forgot if they said that the test will be in the Valencia permanent circuit or somewhere else.
They started with that style towards the end of last year. It doesn't look like they're moving too far away from it either. Below was the new RW they brought to Valencia. Fry said it needs more work & will try it again at Silverstone.Lycoming wrote:How long have they been using that endplate design for? IIRC, they're getting more ambitious in that area compared to the start of the year.
