Red Bull RB8 Renault
atanatizante
134
Re: Red Bull RB8 Renault
Possible routes:
1. Green arrow: radiators exhaust
2. Yellow arrow: first tunnel airflow
3. Red arrow: second tunnel airflow
or maybe underneath the Gurney flap over the diffuser
Why they made this cuts which is seen on purple arrows?
Are they trying to copy W03 slots for second tunnel exit or they just follow the trailing edge of the diffuser?
Jesus
PABLOEING
PABLOEING
In the second 37 you can see the sound of the RB8 in Valencia.....THIS CAR IS NOT LEGAL
http://www.youtube.com/watch?v=VmKcTmZJ ... r_embedded
raymondu999
The FIA acknowledges that the engines are still doing some off-throttle trickery, and have approved it on all the different engines. Or so I hear
失败者找理由,成功者找方法
Owen.C93
Owen.C93
192
atanatizante wrote:[img]http://i.imgur.com/VWe36.jpg[img]
Possible routes:
Purple arrows are modifications to the gurney to match the curved profile of the diffuser edge. I think it's the green arrows and red arrows. The yellow one is too tight and would require more ducts that we couldn't see on the floor or gearbox, which is unlikely.
joeyg02
I'm sorry that my post was rated as "un-useful" which made me receive a -1 rating on a forum I highly respect. I was just applauding the link he posted. I will delete the content.
Thanks,
Joeyg02
Drafting & Design Engineer - I crave information & live in a never ending quest for answers to whatever piques my curiosity.
Joey Griffin - Owner - JG GraphX.
Lifelong Motorsport Fan from Southern Georgia, United States.
Huntresa
Huntresa
joeyg02 wrote:
PABLOEING wrote:In the second 37 you can see the sound of the RB8 in Valencia.....THIS CAR IS NOT LEGAL
=D> =D> =D> =D>
Its just their 4 piston thingie?
Owen.C93
Owen.C93
192
=D> =D> =D> =D>
I haven't heard anything that suggest that is a RBR specific mode.
aral
aral
26
=D> =D> =D> =D>
Don't Red Bull use a THREE cylinder thingie, which has been approved?
hardingfv32
hardingfv32
35
We have been though this before. What is the perceive benefit of using cylinder cutting? In this case are we not talking about deceleration activities?
Brian
Owen.C93
Owen.C93
192
hardingfv32 wrote:We have been though this before. What is the perceive benefit of using cylinder cutting? In this case are we not talking about deceleration activities?
Brian
A smaller displacement engine is more efficient than a high displacement engine that is being throttled more.
Matt Somers
Matt Somers
179
Cylinder deactivation is not new in F1 and something alot of car manufacturers are now using to 'green' their image as Owen says it give the benefit of drivability as if it's a smaller capacity engine. I'd be surprised if all of the teams didnt utilize it in some way for a cornering advantage.
Guisson
Ahh This sound , a little "déja vu" .. :?
Wasn't the RB8 using a trick with the mapping at the end of the year ? ( especially in the tests , and Mercedes was against it )
So will the FIA declare this floor Illegal again? ( if they do i am expecting a sanction for Red bull , In French there is a proverb that says " Jamais deux sans trois" ( never two without three) I think the FIA will ban this double floor at silverstone )
The task is,not so much to see what no one has yet seenbut to think what nobody has yet thought, about that which everybody sees. Erwin Schrödinger
hardingfv32
hardingfv32
35
Owen.C93 wrote:A smaller displacement engine is more efficient than a high displacement engine that is being throttled more.
But isn't the discussion about the sounds made during deceleration or off throttle periods? What is the requirement for efficiency at this point... or drivability for that matter?
Brian
Owen.C93
Owen.C93
192
Brian
That is at low RPM/low throttle parts. Shutting down some cylinders means less pumping losses in the engine. That's the only reason I can think of.
Crucial_Xtreme
Crucial_Xtreme
404
Under this years Regulations teams can cut 4 cylinders on engine over-run when cars are slowing down. Pretty sure they're cutting the cylinders to control torque in said low speed turns/hairpins etc, a place where the RB has seemed to dominate in the past few years. I would suppose it helps on fuel consumption as well.
