Pedal to the Metal wrote:I reckon if Lewis manage to do some overtakes,then he can get a shot at the win,besides,them can start on the harder tyre
I think the last couple have races have shown that the counter strategy doesn't really work. You user the hard tyre whilst stuck behind other drivers on the softs, whilst on a green track that tends to destroy either compound, and with high fuel that is going to take life out of the tyres. Then at the end of the race you are stuck on a slower tyre over the stint, leading to you losing places even if you did manage to gain track position - something that isn't guaranteed.
My own view is that he should start on the option and then be among the first to dive in for the primes. This will either force those in front to react, allowing you to dictate strategy and number of pitstops to them, or give you the advantage of being on fresher tyres for a while, hopefully gaining track position. As long as you then pit again as soon as your tyres start to fade you should keep that track position once all the pit stops have worked their way out. It'll then come down to whether you need to stop again because your tyres won't make it to the end, or if the others will have enough in their tyres to catch and pass. If you know you can't get to the end on those tyres then you can at least make a final pit stop at the most opportune time in order to give you enough time to catch and try to pass the leaders, when the roles will be reversed and you will have the tyre advantage.
The McLarens seemed to spend more time on high fuel than the majority of other teams in P3, so hopefully they have a good setup and enough data to come up with a good strategy. Hamilton, at least, looked very quick in the dry in qualifying, even if Button was his usual couple of tenths behind. I really do hope that McLaren are clever enough to tell their two drivers that it's not worth fighting it out between themselves on track if one is holding the other up. Better to release whichever driver is the faster so that they can both go for their most optimal result, particularly if they're planning differing strategies, rather than them both losing time and tyre life trying to scrap it out. I fear that their efforts to appear fair will lead to them ultimately harming both driver's chances.
