Joie de vivre wrote:brzt wrote:Vettel was clearly out, no doubt whatsoever
I think the curb is a part of the track but yeah still it's a little advantage taking this kind of a line
Nope... the track is the areas between the white lines bordering the track. The curb is outside of these lines.
20.2 Drivers must use the track at all times. For the avoidance of doubt the white lines defining the track edges are considered to be part of the track but the kerbs are not.
A driver will be judged to have left the track if no part of the car remains in contact with the track.
Should a car leave the track the driver may rejoin, however, this may only be done when it is safe to do so and without gaining any advantage.
A driver may not deliberately leave the track without justifiable reason.
