Ya, just remembered he's a different person.
One is a Ho' and the other is a King. how did I mix them up?
I believe before qualifying, then at qualifying they enter perc ferme rules. Please correct me if I'm wrong.Gerhardsa wrote:Button car seems to be bouncing on the rev limiter half way down the main straight already?
When do they have to finalise the gear ratios? Before the weekend starts, only before qualy?
Pretty sure its before qualifyingGerhardsa wrote:Button car seems to be bouncing on the rev limiter half way down the main straight already?
Nope. Fia have to be informed of intended gear ratios within 2 hours of the end of practice 2, changes have to be accomplished on the Friday.strad wrote:Pretty sure its before qualifyingGerhardsa wrote:Button car seems to be bouncing on the rev limiter half way down the main straight already?
Gear ratios must be finalised (and submitted to the FIA) TWO HOURS after FP2 ends. (ie no more mucking about with gears during fp3)RB7ate9 wrote:I believe before qualifying, then at qualifying they enter perc ferme rules. Please correct me if I'm wrong.Gerhardsa wrote:Button car seems to be bouncing on the rev limiter half way down the main straight already?
Yeah, thats why i asked, because I could have sworn I heard somewhere that gear ratios needs to be finanlised. Macca about 10kph down on the quickest (and about 9 down on the average of high 338.xxx kph).simieski wrote:Nope. Fia have to be informed of intended gear ratios within 2 hours of the end of practice 2, changes have to be accomplished on the Friday.strad wrote:Pretty sure its before qualifyingGerhardsa wrote:Button car seems to be bouncing on the rev limiter half way down the main straight already?
probably the actual name of the DDRS, and probably has todo with closing or attaching again...strad wrote:RFA??
