Red Bull RB8 Renault
shelly
shelly
136
Re: Red Bull RB8 Renault
Yes it is allowed. You can put any geomety you want in the central 150mm slice if I remember correctly
twitter: @armchair_aero
raymondu999
"any" geometry? Or an additional section?
失败者找理由,成功者找方法
Matt Somers
Matt Somers
179
Many teams have perforated Monkey Seats this season
raymondu999
Do you have a pic to show what you mean mate? I'm having some trouble imagining what you mean.
失败者找理由,成功者找方法
shelly
shelly
136
raymondu999 wrote:"any" geometry? Or an additional section?
I think anything you want(holes, sections, etc) iirc it is completely deregulated excpet for the minimal surface of the airscoop in lateral view
Flanker27
Flanker27
-2
What about Vettel sparkling for some laps in the end?
Furthermore, the italian TV technical commentator, engineer Giancarlo Bruno, talked about a strange (and maybe illegal) hydraulic device that he discovered in the RB suspension...
the two facts could be connected?
Dragonfly
Dragonfly
These days it seems everything on RBR cars is deemed as "maybe illegal" :)
Is there a link for us to see what particular device the talk is about?
The reason for the sparks is not necessarily something illegal. IIRC last year (or was it this one?) Hamilton drove with a broken undertray support as a result of going over a kerb (Australia?). And no one raised the illegality issue. The concerns were about is it safe to drive with it scraping the track.
Spa 2012
aral
aral
26
Flanker27 wrote:What about Vettel sparkling for some laps in the end?
Newey stated that the skid block, which is sacrificial, was loose and trailing on the ground. There was concern that it would detach itself and hit a rear tyre.
Interesting to see that an Italian commentator was able to see something that all the technical wizards scrutinising the car could not find.
Flanker27
Flanker27
-2
Unfortunately i had to turn off the TV at the end of the race; i'm now reading on some blogs that after the race they showed the images of these hydraulic device in the third element of the suspension... so they speculate about a "setting adjuster" (sorry for the bad translation)
I'm also looking for some pics/video
variante
139
gilgen wrote:Interesting to see that an Italian commentator was able to see something that all the technical wizards scrutinising the car could not find.
That italian commentator (an engineer) saw that detail in some TV images.
Those images show RB technicians putting a small metal piece, with (what seems to be) an hydraulic link, near the front suspensions area.
gilgen wrote:Newey stated that the skid block, which is sacrificial, was loose and trailing on the ground. There was concern that it would detach itself and hit a rear tyre.
do you really think that Newey would say things as they are in these circumstances?
aancora
Hi guys, I'm a new member but I always read your forum :)
Dragonfly wrote:These days it seems everything on RBR cars is deemed as "maybe illegal" :)
aral
aral
26
So now it is someone who saw some TV PICTURES , with a small metal piece being inserted, with WHAT SEEMS TO BE a hydraulic link?
The car was scrutinied . Why start rumours?
And as for Newey. He has never told lies before, to my knowledge, so why insinuate he is lying now? It was obvious that the skid block was rubbing. So what? That is what it is there for....to prevent the floor from rubbing the ground. It is not the first car to be seen sparking.
munudeges
munudeges
-14
Flanker27 wrote:Furthermore, the italian TV technical commentator, engineer Giancarlo Bruno, talked about a strange (and maybe illegal) hydraulic device that he discovered in the RB suspension...
Strange no one else has seen it and strange that it has only cropped up now that Red Bull have found some speed. If they did have some magic device they would have had it on all season and they would have had a massive advantage long before now.
It doesn't surprise me that these desperate soundbites are being thrown out now at this point in the season.
Kiril Varbanov
147
There's certainly no concern over the sparks, I suppose it was debris that Vettel has got. Apart from that, there are small vertical titanium skid blocks which are actually measured for floor's wear.
RB8 looked really gentle on tires (VET), and very fast, obviously, although down on top speed, which was a deliberate move.
What was WEB's KERS issue - overheat? Could not get that during the race.
gandharva
gandharva
252
Yes, overheat.
