turbof1 wrote:I am getting here alot of people insinuating that as long as the driver has 0.5 liter + fuel for one lap on board, it is ok to pull over. That is incorrect: you need to make it back to the pits; if you don't you need to provide enough proof that the driver was forced to pull over due a technical issue.
True except it is 1 liter and only necessary fuel to finish your inlap. You can stop your car 10m before the pitlane with only 1.1l onboard without facing penalty if you had a genuine technical issue.
Talking about penalty, I don't get what it is so difficult for some to understand:
- not enough fuel: DSQ
- gearbox change: 5 place penalty
- engine change: no penalty except if you mount your 9th fresh engine (10 place penalty). Engine which was replaced could not be used during qualifying session or race anymore.
- driver change: err... nevermind, qualifying are over.
- anything else : no penalty
