It will have max. height (100%) , but we can't deduce this from the pic.
nearly all noses( except Marussia) will be stepped (and nearly all stepped will be covered with modesty panel ) in 2013
And how are you so sure? If it was to full height you would have seen the front edge of the tub due to the camera positionFrukostScones wrote:It will have max. height (100%) , but we can't deduce this from the pic.
compare the McLaren pic (a lousy pic) to this: http://www.youtube.com/watch?v=uzJqTxaF_iMwesley123 wrote:And how are you so sure? If it was to full height you would have seen the front edge of the tub due to the camera positionFrukostScones wrote:It will have max. height (100%) , but we can't deduce this from the pic.
That actually proves my point.FrukostScones wrote:compare the McLaren pic (a lousy pic) to this: http://www.youtube.com/watch?v=uzJqTxaF_iMwesley123 wrote: And how are you so sure? If it was to full height you would have seen the front edge of the tub due to the camera position
Yeah, almost a year ago, for like 15 minutes. And after that it was never mentioned again.and we all now they tested for high tub (to check visibility) with a thing attched on the tub/bulkhead and whatever.
Yeah because a high nose gains like 1 second. An high nose, and certainly when it is only raised for like 5cm barely gains anything. To say that with an high nose they will be unbeatable is just plain stupid.They will have a high front and will be unbeatable.
I know that this is a speculation thread but, in my oppionion, you are deceiveing people who come here for the first time and see your post (and may take is as a fact). How can you know for sure in a speculation thread? Tell me some good reasoning that backs up your 100% knowledge about the fact that it's going to be a high nose. It may well be true and we'll see it on the 31st, but it would be better to keep it "speculative" for now.FrukostScones wrote:we'll see on 31st?, we already know now. =D>
You know something for sure, when you know something for sure you have arguments, you have proof.FrukostScones wrote:If I knowsomething for sure why should I speculate.
before I knew, I said well high nose because of this and that maybe not enough foundation basing my speculation (ok), but
white helmet guy said and is trusted, so bingo!
