Williams FW35 Renault
user001
user001
-2
Re: Williams FW35 Renault
the new FW looks like the FW lotus used last year regarding the nosecone.
Skett
Skett
Seamus wrote:@f1technical
AMuS have learned that Williams will introduce a ramp-style exhaust tomorrow, following Lotus and RBR, two other Renault powered teams
This makes me wonder what the whole point of the exhaust fin was then. Testing the waters for something else, or just trying to distract our attention from the blown wheelnuts?
raymondu999
IMO it makes it clear that they wanted to almost make an entire tunnel to completely funnel the exhaust down to the gap between the floor and the tyre. Sort of a super extended acer duct, if you will.
Interesting that the Renault runners seem to be converging on the ramp/tunnel idea. Perhaps the Renault engine, even without fancy mapping, produces more exhaust gases when off throttle, compared to their rivals? I remember that the Renault used butterfly valves for the throttle while the other two don't. Could that be it? Or I could have it the wrong way around.
失败者找理由,成功者找方法
beelsebob
beelsebob
85
raymondu999 wrote:IMO it makes it clear that they wanted to almost make an entire tunnel to completely funnel the exhaust down to the gap between the floor and the tyre. Sort of a super extended acer duct, if you will.
Certainly it was renault who moaned that they needed to keep blowing gasses out for cooling purposes when the FIA first tried to clamp down on it.
imightbewrong
imightbewrong
Ramp style exhaust today!
zoro_f1
-2
they are using coanda with under channel.
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
Barcelona (Test 3, Session 2) - Day 3 (02.03.2013)
Bodywork around the gear box looks different to me too
DarkJRO
Blackout wrote:Bodywork around the gear box looks different to me too
could be the outlet for the tunnel under the exaustramp
Greetings
Dark JRO
Yes
Forza
238
Another look at FW35 new exhaust at Barcelona today
Doesn't this look more like the original RB tunnel than the later versions?
Floor is different too, now it has strakes infront of the tyres.
Interesting, seems like the tunnel's exit is in the low central area where the new bodywork is
New 'double' bargeboards too
beelsebob
beelsebob
85
It seems bizarre to me that the team with the strongest, tightest coke bottle are testing a system that's known to impact the effect of the coke bottle.
