Williams FW35 Renault
Re: Williams FW35 Renault
roadie wrote:I don't avow to understand aerodynamics, but the intake under the ramp seems very small compared to the amount of free space there was at the rear of the car before the ramp. The ramp takes up a large footprint in front of the rear wheels on the FW35! Also the ramp intake exit next to the gearbox fattens the famously slim rear end.
Hope it works!
They have a small hole for big exit area, i think the air should expand nicely, without choking.
Matt Somerfield
Williams FW35 - Front Wing detail, notice how the endplate severs contact at the rear to allow air to move inside
Matt Somers
Matt Somers
179
Sevach wrote:Is there a slit on the top of the sidepods now? Look below the mirrors.
http://www.f1fanatic.co.uk/wp-content/u ... 86x590.jpg
Been there since the launch, I mentioned it at the time, this is the first time in ages it's been opened up though ;) It's like the hole McLaren used to run on their Sidepods
I remember the Mclaren one, 2010 or so.
It's so forward, does it even go through the radiator?
Matt Somers
Matt Somers
179
Sevach wrote:I remember the Mclaren one, 2010 or so.
McLaren ran it until they went to the Sidepod WIngs last year, some races it was there others it was absent, it is forward on the rad.
Barcelona (Test 3, Session 2) - Day 4 (03.03.2013)
raymondu999
It almost looks like they're exiting the sidepod tunnels near the crash structure
失败者找理由,成功者找方法
drunkmunky
drunkmunky
That's interesting...
The IRBR uses the tunnel to blow the starter hole, perhaps Williams is using the tunnel to blow the bottom of the beam wing for greater Down force effect.
CottrellGP
CottrellGP
drunkmunky wrote:That's interesting...
You sure the IRBR is blowing the starter hole? the latest picture i seen you could see the starter hole
Dan Cottrell
Master Of Innovation!
they do
Forza
238
Owen.C93
Owen.C93
177
they do
Not directly. They exit around and below the gearbox.
Car is ready to travel back to the UK
via Dickie Stanford
Owen.C93
Owen.C93
177
Strange nose.
tomazy
tomazy
208
It is probably just for transport.
