F1 Malaysian GP - Thursday - 21/3/2013
Yes, there are many holes on an F1 car to let out hot air from cooling.hichamo wrote:hello everyone,
it's my first time here and i hv to say this is the best technical f1 site ever.
anyone noticed the opening on the side of the exhaust?? that little U shape.
it was closed in australia, do u guys think its legal to leave it open??
Hey welcome to F1technical, hope you are talking about this pichichamo wrote:hello everyone,
Just look at the pic from Lotus and now look at the part ahead of rear tyre from where the coaxial cable is protruding.Crabbia wrote:One possible location for the rear tyre temp sensors is here:http://www.formule1.nl/media/uploads/me ... 296.94.jpgLow_drag wrote:Ok, I agree it's not a bolt, but a sensor of some sort, yes. Is it an IR camera, No. Is it an IR sensor for pin point measure ment on tire temp, plausible. I wonder where the sensors are for rear tire temps if they are collecting real time temp's.
On the floor, ahead of the rear tyre there is a elliptical "bubble" with the rear face of the bubble cut out. I think the rear face is cut out cause the sensor pointing out of that face. I haven't seen a shot of it with that face front on to confirm though.
This pic is a bit grainy but it you can see what I mean:
https://pbs.twimg.com/media/BEbUqldCMAA2b6g.jpg:large
And agreed I will call it a IR sensor from now on. Although i still think it is giving them 2D images in real time of the heat buildup and dissipation across the outer face of the tyre and not just point temperature readings but we can agree to disagree on that one no?
thx,F1.Ru wrote:Hey welcome to F1technical, hope you are talking about this pic http://i.imgur.com/1YarXxW.jpghichamo wrote:hello everyone,
The opening outside of the exhaust is merely to cope with more heat and hot temp of Malaysia, so they open the cutout part which will help to provide additional exit for the radiators and thus provide faster cooling. another things is that as they positioned outside the exhaust thus it will not interfere with the exhaust plum rather will assist it towards the rear end.
