No, my point was not that the driver was being cooled from there, my point was that if you wanted to cool the driver, there's a simpler solution than messing about with holes in the splitter and piping air around in circles. That implies that pipes in the splitter are there for something other than that.allstaruk08 wrote:the lotus doesn't have a hole in the tip of the nose... so the driver isn't being cooled from there.
Okay, I can believe that the hole there is for driver cooling – I'm not convinced though that it goes through the tea tray support.i never mentioned the tub support i was on about the hole on the tub just above the tray (that will be pretty much infront of the drivers arse),
Sure, that's entirely plausible. The question is, what (if anything) is flowing through that tube. The shape of the tube (trying to avoid sharp corners anywhere) certainly seems to imply to me that there is something flowing through it, as does the hole in the tea tray under it, and the fan plugged into it.but since you mentioned the support just because other teams use a titanium rod doesn't mean lotus have to do the same maybe they get a aero benefit from running a specific shaped support
Basically, I don't buy that the tea tray support is carrying driver cooling air. I do buy that the slot above the tea tray is. I don't buy that the two are connected to each other.
