Diesel wrote:Right back at you, what specific evidence do you have to support that it's a code that means "car number 2 leads car number 1" ?
Oh sir, it is but my pleasure:
Webber was leading the race after the final stops, the Mercedes threat receding as Hamilton desperately saved fuel, so team orders were imposed. 'Multi 21' both drivers were instructed,
a code that essentially means turn everything down, cease racing, hold position, save the tyres.
Source
Reading between the lines of Horner's explanation to the media after the race,
the coded - and now infamous - 'multi-21' message to hold position would appear to have been given promptly after both drivers had completed their second stops on Lap 43: "When that last pit stop was complete, Mark was ahead - it was very close on pit exit. As far as we were concerned, it was a matter of managing the tyres to the end of race...and the instruction was given to both cars to effectively hold position."
Source
As the fallout from Vettel disregarding
Red Bull's 'Multi 21' team order so he could beat Mark Webber continues, the squad issued a short statement on Monday night.
Source
The Australian gave Vettel the cold shoulder before the podium presentation, saying only "Multi-21, Seb. Multi-21" -
a reference to Red Bull's race instructions.
Source
Sebastian disobeyed team orders and most, if not all the team, are disappointed with him," he said.
Source
Now, I have obliged, as I have done in the past and can continue to do so - as you can see the media reports are vast and from reliable sources. I have given you a range of sources - all saying the same thing -
Multi 21 is not a specific setting - but a code. Now if you and your mate SaX would be so kind to front up your evidence to support your theories - we can compare - but alas, at each opportunity none of you have. You're both fast with the back talk - but quite remote on hard facts.
sAx wrote:Though you seem lost between what you will and won't accept, that's great to hear!
Not at all, I have offered evidence to support my theory - you have not. I have said many times that I am open to accepting your theory - if I see evidence - which you have never once supplied. You're trolling now - go away.
Is Multi 21 a code? All sources seem to indicate so. I'm not closed off to seeing evidence that it is indeed a
specific setting that overides all other setting to put the car into cruise mode - but failing any multiple reliable sources that can confirm it - then this topic is closed.
edit: typos
