Some questions:
1. If they start on wet/intermediate tyres and afterwards is dry and everybody went onto slicks then is a rule stating you must run both tyre compounds?
2. Why Lewis run out of fuel?
a) They gambled on a wet race?
b) Or a pace car situation?
c) Or maybe they don`t figured it out how much fuel needs their Coanda exhaust system?
3. Does anybody know from which lap he was forced to run a fuel economy engine mapping, coz based on the lap times, seems to me he did that after lap 31 …
http://184.106.145.74/f1-championship/f ... alysis.pdf
4. Anyway if they had in mind that the final stint should be a cruising one why they decided to run option tyres then?
5. On lap 31 Hamy went onto the prime-hard tyre and he could manage only 10 laps, but with option tyres he did a 14 lap first stint when the car was heavy. There was a problem with this set of hards? Inadequate pressure or they modified FW AoA?
6. What`s the delta speed between a car with DRS on and a car with an off one?
7. Why Hamy has Carbon Industries carbon disks and what`s the difference between these and Rosberg`s Brembo is using?
8. Who was on a dry setup and who was on a partial or full wet setup?
Seeing the true picture of the present Formula 1, I`m on the side of those who want to see pure racing and not drivers who are cruising and nursing their tyres.
Having said that I will follow the demanding need for a decreasing Formula 1 budgets, knowing we are facing a world in deep crisis, therefore I am calling for a petition to FIA stating the following amendments:
a) At any race there will be at least 3 mandatory pit stops.
b) There will be only one compound of tyre for the whole weekend: FP1, FP2, FP3, Q and race.
c) The tyres must last half of the race distance or at least 20 laps with a delta time loss between the first one and the last one somewhere in the range of .5 and 1 sec.
