That's because when they run without exit pipe the ears were closed, IIRCHuntresa wrote:How do you know there is only one version ? If anything Lotus should have two since they have worked on it the longet.Blackout wrote:There is only one version. Lotus used two different rounded monkey seat though.
Sure the low pipe isnt there on one and that might suggest its not the full version but then again why would they run a system that obv then wouldnt work if you need the low pipe?
