Maybe this will not see the light of day until next year....
Also, and in line with someone commenting on Mercedes employing a tyre guru... They have.
Back in 2010 I recall... A Bridgestone fellow.
I take it you missed every FP session then? since all weekend they focused on their long runs and to see if they had fixed their tyre deg problems, they definitely didn't set their car up for Qualy only, they did the opposite actually.McG wrote:Don't know if it's been said before, but Mercedes setting up the car for qualifying glory then going backwards in the race is not cool.
What can you see visually that Mercedes can implement from Lotus?marcush. wrote:they claim to understand for quite a while now ...
it sure is depressing to watch them fail to identify the solution and implement it.Obviously there are people around who know what to do I do not subscribe to the theory Lotus does not know what they do right with tyres.
The frustrating thing is exactly that, they knew the maps before the season started and obviously knew the power delivery of their engine. So if this is the problem - and it's a big if - they didn't do their job properly.FoxHound wrote:What can you see visually that Mercedes can implement from Lotus?marcush. wrote:they claim to understand for quite a while now ...
From what Mercedes have said, it is in the preparation of the tyre that they are failing....they assume. Everything is being looked at here, as all efforts to regain some form of control of degradation have thus far come up short.
My own opinion is that it is a combination of things that exacerbate the problem.
FRICS allied to the Mercedes V8 power delivery is a massive issue, Mercedes haven't really suffered front end problems as they have with the rear. And, as maps are limited an have to be presented before the season start you have no lee way in "tuning" the engine for optimal delivery from track to track.
In a nutshell, the problem could be "frozen in" for a season. Given past history of the team with tyres I have to say I'm pessimistic as to a solution being found this year.
I thought exactly the same with Aldo Costa, but sadly the results are far from being good.Gridlock wrote:Paddy Lowe might.Vasconia wrote:the problem comes from pre-Mercedes era and i cannot see a solution for this.
Lewis and his Bulldogs reaction:Cocles wrote:This falls in line with the preseason rumor that they're now working with an American company on a radical cooling solution.k.ko100v wrote:The second one is some kind of revolution cooling system, which use 30% less liquid. This would give an aero advantige and would compensate the increased fuel at the start of a race (which is their second big problem).
I think FRIC is more about controlling the aero platform more than an increase in mechanical grip. Obviously, I could be wrong.yener wrote:Lets wait and see what happens in Monaco. Last year Michael was the fastest guy in Qualy.
Thing the mechanical grip is not bad and with the fric system it has to be improved. I'm sure both cars will be in top 5 at saturday.
Fric is an interlinked suspension system which connects all the tyres (suspension) which each other. Cant see what it has to do with aerodynamics. If you would say that fric is screwing the aerodynamics in mid and highspeed corners i would understand. But like i said earlier, we all have to see and wait what happens in the next race. Mechanical grip is everything in monaco.Pierce89 wrote:I think FRIC is more about controlling the aero platform more than an increase in mechanical grip. Obviously, I could be wrong.yener wrote:Lets wait and see what happens in Monaco. Last year Michael was the fastest guy in Qualy.
Thanks for explaining what "controlling the aero platform" means. I lose my patience when someone says suspension has nothing to do with aero(especially in an f1 context).marcush. wrote:fric is not aero in itself but one of its main benefits is pitch control of the car and that is almost entirely driven by aero needs (rake - pitch stability under dynmic loads will help you to keep the car in favoured areas of the aeromap of the car)
with a groundeffect car vertical response of the car is always there to help aero first and then only to help other needs one might have.
