Ferrari F138
F1.Ru
21
Re: Ferrari F138
Craig Scarborough wrote:Canadian GP technical round-up
FERRARI F-138
The weather interfered with Ferrari's running of a new aero package during the Spanish Grand Prix and the parts appeared again during Friday practice in Canada. Joining the previously-tested revised front wing mounts, Coanda sidepods and sidepod vanes, was a new front wing design along with a chin being fitted under the nose. Throughout practice, the team ran back-to-back tests with differing set-ups. It's not clear what will be used for qualifying and the race here.The front wing is the most interesting part. The cascade winglet mounted to the wing's endplate has completely changed. Rather than being a horizontal wing, the element is now curved such that it meets the wing in an 'r' shape.
The revised cascade wing will probably create downforce, but the change is more likely to be about modifying the way the winglet bends the airflow around the outside of the front tyre. The new outer vertical section of the winglet will be quite effective at turning the airflow .Further aiding front end airflow is the small chin below the nose. Most teams have these 'pelican' or 'pregnant' bulges under the nosecone. They work with the neutral wing shape in the middle of the wing and the wings mounts to alter the airflow back along the edges of the car.
I'm told these chins also add downforce to the front end even though their design is counterintuitive at first sight, as it appears they would add lift not downforce.
Formula One is a game.............. but not any ordinary game for me
kosioBG
86
Re: Ferrari F138
I wouldn't say this is a "completely" new front wing. Just the cascade flaps are new, the other components are the same, aren't they?
Alonso Fan
Re: Ferrari F138
kosioBG wrote:I wouldn't say this is a "completely" new front wing. Just the cascade flaps are new, the other components are the same, aren't they?
yep, just the cascades are new
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
Re: Ferrari F138
The front wing might not be "completely new" but expect a huge change in airflow in this area. Though the change might not look so big on the eye, in terms of performance it takes a much larger change, and possibly more potential
Re: Ferrari F138
Definitely the airflow around there has changed a lot because the air is "attaked" in a different way and I presume they thought a lot and made lots of simulations before adopting this solution that apparently works.
shelly
shelly
136
Re: Ferrari F138
fantastic find from f300v10 and magnfication by sectorone. In my opinion this tiny vortex is generated by one of the strakes below the flap
twitter: @armchair_aero
Owen.C93
Owen.C93
177
Re: Ferrari F138
Yeah that's an incredible shot, nice catch.
Re: Ferrari F138
It is actually quite a big vortex. There are numerous vortices around the car, almost none are visible. That one there is a very strong vortex. And it seems to be working, acting like a shield to stop normal airflow from bouncing on the wheel. Ferrari might complain about aero dominating f1 these days, they have creating a true masterpiece of aero there.
Kiril Varbanov
147
Re: Ferrari F138
turbof1 wrote:Ferrari might complain about aero dominating f1 these days, they have creating a true masterpiece of aero there.
The number of aero developments on the F138 is actually quite impressive, and it was expected, to some extent, according to ex-Ferrari engineer I've talked in pre-season. Personally I wasn't expecting such large number of aero details, given the previous conservatism driven by the lack of tools, namely wind tunnel. Looks like the Cologne-Toyota move has started paying dividends. I'm counting 8 areas of aero developments at prima vista.
RGV_Rider
RGV_Rider
Re: Ferrari F138
i have tried to get the starting point of the vortex.. if you look close to the right wheel you could see it.. :D
SectorOne
Re: Ferrari F138
shelly
shelly
136
Re: Ferrari F138
I think this is tiny compared to the y250 vortex , bargeboard vortex or fwep vortex - I have tried to collect all this type of pictures in the "wing aero " thread (http://www.f1technical.net/forum/viewto ... =6&t=14939) and there are bigger vortices
As far as the origin edge, it could be the cascade, like rGV_rider pointed out - but to me it seems too close to the tyre for being it, that's why I thought about the strake, but I may be wrong. I hope we will have more pictures like this to learn more
Kiril Varbanov
147
Re: Ferrari F138
Piola with video on F138 brakes.
Huntresa
Huntresa
Re: Ferrari F138
But the strakes are closer and i dont think they would bend up like that, i mean the whole cascade is shaped to move air upwards and around or just upwards and over.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F138
The new F138 FW & new brake/brake duct analysis from Gary Anderson.
via AutoSport
via AutoSport
