Lotus E21 Renault
Kansas
Kansas
-3
Re: Lotus E21 Renault
was hoping for new coanda and sidepod.........
btw, rbr was running new coanda in Fp1.
Good comparison. So new engine cover + Ferrari-style fin along with rear bodywork - exactly the things Alan was talking about.
Great Britain 2013 - Friday (28.06.2013)
Opened ears and the flow conditioner inside the airbox is back
via AMuS
via Lotus F1™ Team
Is it me or the right DRD intake (the one on your left) is longer than the other one ?
Kansas
Kansas
-3
anyone can list out the new upgrades???
im having a hard time to identify whether the sidepod is new..
quidam
quidam
Blackout wrote:Is it me or the right DRD intake (the one on your left) is longer than the other one ?
http://photos.gpupdate.net/large/225163.jpg
I don't think :
Kansas wrote:anyone can list out the new upgrades???
● New engine cover with central (a-la-Ferrari) fin;
● New rear, tighter bodywork (that works with the engine cover);
● Slightly reprofiled monkey seat;
● Some suspension-related modifications (we can't see it, but Alan Permaine mentioned them last week)
● New front wing (also mentioned by Alan Permaine).
● There might be something new to the floor also
F1T
Administrative bot
Skinnier bodywork on Lotus E21
Skinnier bodywork on Lotus E21 - Development blog
Lotus have introduced a new bodywork package on their E21 which appears to be a lot skinnier ahead of the rear wing. While Raikkonen was still running the old package, a few times even with DRD, Grosjean's E21 had this new package which looks unsuited for DRD, even though the inlets are still present.
One of the most interesting bits is the outlet of the sidepod's hot air. Where most teams aim to dump that close to the floor or through a Red Bull style funnel ahead of the monkey seat, the new Lotus package features a shallow triangular shape, blowing air onto a wide central section of the beam wing. Its shape appears to be designed to remove any obstacles in the airflow higher than the sidepod's shoulders. This in return should increase the efficiency of the rear wing.
ebare
ebare
Aside being difficult to reason what advantge would became whith a asymetric air intake, that would be illegal.
3.16.1 With the exception of the opening described in Article 3.16.3, when viewed from the side, the car must have bodywork in the area bounded by four lines. One vertical 1330mm forward of the rear wheel centre line, one horizontal 550mm above the reference plane, one horizontal 925mm above the reference plane and one diagonal which intersects the 925mm horizontal at a point 1000mm forward of the rear wheel centre line and the 550mm horizontal at a point lying 50mm forward of the rear wheel centre line.
Bodywork within this area must be arranged symmetrically about the car centre line and, when measured 200mm vertically below the diagonal boundary line, must have minimum widths of 150mm and 50mm respectively at points lying 1000mm and 50mm forward of the rear wheel centre line. This bodywork must lie on or outside the boundary defined by a linear taper between these minimum widths.
Definitly optic illusion.
Bodywork around the G-box looks nice from that view angle. I wonder if it contains Redbull like cross tunnels : P
Lotus also tested new front brake ducts today. They are similar to the Williams ones.
http://cdn-2.motorsport.com/static/img/ ... 2/s1_1.jpg
http://www.f1technical.net/development/355
But not as 'scoopless' : P
Silverstone
Canada
Alan Permane ‏@AlanPermane
Kimi will stay with the new 'device' through P3 and very likely Q and Race
Great Britain 2013 - Saturday (29.06.2013)
Lotus F1 Team ‏@Lotus_F1Team 1m
New svelte bodywork remains for R.Grosjean. No 'Device'.
So "the device" and the new rear bodywork are pretty much working as they expected.
Forza
238
British GP - Saturday FP3 -29/06/13
So they are running it in qualy and race? If I am correct, the DRD never got this far into the weekend.
gary123
http://translate.google.it/translate?hl ... rregolare-
looks like lotus haves an illegal front suspension since montreal.
