WhiteBlue wrote:I don't think it can be beaten unless you undertake a similar effort as Peugeot did. The 208 T16 is a rocket ship with above F1 performance on a hill climb. 695 hp for a 675 kg car is F1 standard, but you actually accelerate faster on the hill because the tubo engine has superior traction by using all four wheels to push the car, which F1 will not do. The car was 100% LMP1 engine technology with zero restrictions on the special chassis. It requires a works team with the technology and experience of Le Mans LMP1 to repeat or beat that performance and then you will have to find a competent driver preferably with rally experience who is prepared to risk his life like Loeb did for this one off. I would say that Porsche might be able to do it in some years with a guy like Kubica or Webber and a $30m budget.
I both agree and disagree. I would separate into two separate categories here. One being the performance of the car itself and the other being the overall performance.
The overall performance of the team was as you would hope for from a great team. If you dont know they are there, they performed flawlessly. The driver is obviously exceptional. The funding was obviously large. This will not be easily duplicated but its certainly not impossible, especially if the event continues growing.
Their recipe was simple. Transplant aero from the LMP car (millions already spent) so it has some decent downforce, put some big power in it, 4wd and one lunatic driver behind the wheel. This is potent and must be respected, however I do not see the car to be the ulitmate. I would start with suspension and aerodynamics. Even if you managed by some miracle to have all those aero bits function at 100% as well as they did on the LMP when transplanted into a different car, you are still looking at a very small downforce value compared to what is possible with no rules whatsoever. I am certain that a purpose designed aero package for hill climb, even by the same group hat did the LMP car could have a lot more downforce. There can be little doubt about this. The diffuser for example is specified in the LMP regs and drag is totally out the window with 800hp and a top speed of 200kmh.
A modern LMP car is designed around extreme aero sensitivities, drag, tight competition inside of a rules box, appearance requirements and others. The peak downforce values documented for something like group C compared to current LMP cars are double. With no rules at all group C era numbers are exceeded "easily" when you are talking about big budgets and no rules.
Tire manufacturers being motivated is probably another place for huge potential increments in performance as well even with no changes to the car. This is in no way taking a swipe at the team or their phenomenal achievement, quite excellent without a doubt.
The point I disagree on is that it will require a similar effort... thats a question of timing. Things tend to get cheaper over time. Good ideas trickle down and people come up with cheaper ways of doing them. Its only a matter of when... so I think its possible for a smaller effort to beat that record in the not too distant future.
