Blackout wrote:It's just an old pic I took from a post I posted here before the start of the season and where I wrote something like: ''this are the updates Lotus will bring soon''. The pics shows many of the tweaks the E20 received during the 2012 season, tweaks that Lotus did'nt implement on the new E21. Lotus is indeed bringing them back one by one since the last Barcelona tests/Melbourne.
That's why I said nowadays it's easy to predict what updates Lotus will bring...
The second reason is the fact that Lotus copies the 'latest' fancy technical tricks of the grid very late... that's what I mean.
May it be because there are some circuit-specific solutions that are (conceptually) being repeated every year as long as there are no major regulations changesBlackout wrote: That's why I said nowadays it's easy to predict what updates Lotus will bring...
Why would you need to move a frontwing forward and a longer nose if that is attached to the point that has not moved from wheel centre line. If I'm not wrong the section behind the front wheels centre line is stretched (because otherwise you won't get longer wheelbase) and nothing has changed ahead of the front "axle"McMrocks wrote:Regarding the longer wheelbase:
Also you have to move the frontwing more forward since the area where no bodywork apart from the suspension is allowed is moved forward, thus you have to move the whole FW forward and therefor you need a longer nose.
from what i understand they just change the wishbones to move the front wheels forward. At least AMuS said that.ptw wrote:Why would you need to move a frontwing forward and a longer nose if that is attached to the point that has not moved from wheel centre line. If I'm not wrong the section behind the front wheels centre line is stretched (because otherwise you won't get longer wheelbase) and nothing has changed ahead of the front "axle"McMrocks wrote:Regarding the longer wheelbase:
will you name it E27 just because wishbones are different?McMrocks wrote:from what i understand they just change the wishbones to move the front wheels forward. At least AMuS said that.ptw wrote:Why would you need to move a frontwing forward and a longer nose if that is attached to the point that has not moved from wheel centre line. If I'm not wrong the section behind the front wheels centre line is stretched (because otherwise you won't get longer wheelbase) and nothing has changed ahead of the front "axle"McMrocks wrote:Regarding the longer wheelbase:
Why wouldn't you get a longer wheelbase if you move the front wheels forward?
