New front wing, the small slot in the end plate is new.
Also the new nose seems much higher and thinner compared to previous solution
The nose doesnt dip down. Its flat and straight forward and much more square like Merc new nose at Nurburg i think they introduced theirs.gilgen wrote:I have seen that small slot in the end plate before.
Re the nose, do you mean NARROWER? As the nose appears to be considerably thicker than before.
You have to take into consideration that they have raised the nose though.astracrazy wrote: i can't get my head around how the car can still be balanced with a hungry wing and a spa wing but still keeping the aoa for the front with the same. It seems there should be a lot of downforce being lost at the rear but there isn't and thats the bit i don't understand because the rear wing is responsible for so much
But dear 'friend' diffuser, the speed trap in SPA is at Raidillon and not at the end of Kemmel Straight..diffuser wrote: Dude! Go to http://www.formula1.com/races/in_detail/ choose the track, they tell you what the average speed is of a corner. Read analysis of the track before the GP. They explain the track. After qualifying (if you're not using anything else while watching, I use F1LT) go to http://www.formula1.com/results/season/ ... _trap.html. It's not an exact thing but it gives you an idea. You can see that Vettel is 3ird at the speed trap, if you look at previous races, he's usually near the bottom.
