I don't see a problem with that. Not regulation wise. As long as the ratio is fixed.autogyro wrote:So what if you wanted to use a planetary gear set with an electric clutch?
It is a bit late for that I think. It also may be a general problem to measure such uneven, pulse flow with 0,5% accurracy with any sensor.Holm86 wrote:Then there is only two options. Rewrite the regulation on sensory tolerances or find another supplier.
Then what would you do?? Say the secret magic words that makes the sensors more accurate???piast9 wrote:It is a bit late for that I think. It also may be a general problem to measure such uneven, pulse flow with 0,5% accurracy with any sensor.Holm86 wrote:Then there is only two options. Rewrite the regulation on sensory tolerances or find another supplier.
Holm86 wrote:Fixed ratio means that a gearing is allowed. I doesn't have to be 1:1. It could be 1:2, 1:4, 1:5 whatever you like.
Just means that only one gearing is allowed.
And may be clutched just means you choose weather you want a clutch or not.
So long as the planetary gear set has only one ratio (no gear changes) and the electric clutch does not slip at any point other than the fractions of a second required to engage or disengage.autogyro wrote:So what if you wanted to use a planetary gear set with an electric clutch?
The dual boost could be allowed if the double sided compressor is a one piece unit. My reading of that regulation suggests that if the compressor is made up of two single sided compressors mounted back to back it may be illegal.dren wrote:5.1.6 Pressure charging may only be effected by the use of a sole single stage compressor linked to a sole single stage exhaust turbine by a shaft assembly parallel to the engine crankshaft and within 25mm of the car centre line. The shaft must be designed so as to ensure that the shaft assembly, the compressor and the turbine always rotate about a common axis and at the same angular velocity, an electrical motor generator (MGU-H) may be directly coupled to it.
This excludes the dualboost compressor. It also likely kicks out axial turbines since that would be best used in a multi stage configuration. Although if you run very high backpressure, an axial turbine might not be a bad choice or no?
One of the major benefits of the dualboost unit is its low inertia, helping it spool quick. This will not be much of an issue with the MGUH attached.
The turbine will, most probably, be producing more shaft power than the compressor can use well before 10,500rpm. Thus the MGUH should be generating at least some power before then.Holm86 wrote:I don't agree with this. It all depends on how you harvest the energy. You are right that with less mass you can harvest less kinetic energy. But this is not about harvesting kinetic energy. You want to harvest waste energy.Harvesting from gathered energy could became weaker (less inertia, less stored rotational energy)?
The way i see this working is that you use the MGU-H as a harvester when maximum boost is reached. You use the MGU-H as a generator to control the boost. This is why some of us including me thinks that wastegates are redundant.
So at 10.000 rpm when max fuel is allowed this rpm should be when max boost is as well. From 10.000-15.000 boost should drop to compensate for the increase in air flow the engine creates itself when increasing revs. So you brake the turbine with the MGU-H and harvest the excess energy. The rotating mass only has something to say in the time between to fixed numbers. ect. when you brake the turbine from 125.000 rpms to 100.000 rpms. The time it takes for the turbine to get from speed A to B is the time where you would be able to harvest more energy with higher mass. But i dont think the MGU-H will be used to brake the turbine like that. It will be used to maintain a surtan rpm or slightly reduce rpm after 10.000 rpm engine speed.
The rules are against 2 stage compression. I don't think the dual boost is 2 stage. It looks like parallel compression.wuzak wrote:The dual boost could be allowed if the double sided compressor is a one piece unit. My reading of that regulation suggests that if the compressor is made up of two single sided compressors mounted back to back it may be illegal.dren wrote:5.1.6 Pressure charging may only be effected by the use of a sole single stage compressor linked to a sole single stage exhaust turbine by a shaft assembly parallel to the engine crankshaft and within 25mm of the car centre line. The shaft must be designed so as to ensure that the shaft assembly, the compressor and the turbine always rotate about a common axis and at the same angular velocity, an electrical motor generator (MGU-H) may be directly coupled to it.
A single two sided compressor may make the assembly difficult to put together.
The rules say "sole single stage compressor". As in one compressor. The dual boost uses a double sided impeller. If that impeller is made up of two pieces it may be argued that there are two compressors.ringo wrote:The rules are against 2 stage compression. I don't think the dual boost is 2 stage. It looks like parallel compression.wuzak wrote:The dual boost could be allowed if the double sided compressor is a one piece unit. My reading of that regulation suggests that if the compressor is made up of two single sided compressors mounted back to back it may be illegal.dren wrote:5.1.6 Pressure charging may only be effected by the use of a sole single stage compressor linked to a sole single stage exhaust turbine by a shaft assembly parallel to the engine crankshaft and within 25mm of the car centre line. The shaft must be designed so as to ensure that the shaft assembly, the compressor and the turbine always rotate about a common axis and at the same angular velocity, an electrical motor generator (MGU-H) may be directly coupled to it.
This has also been discussed here before. And yes i do think that most of us believe this is the way to go.langwadt wrote:has anyone considered putting the mgu-h in between the turbine and compressor?
Aren't these sensors placed between the pump and the injector?Holm86 wrote:And why is it a pulse flow?? I would think the flow is pretty smooth and constant.
There is a feed pump, a high pressure pump and then the injector. The sensor is placed in the tank after the feed pump.piast9 wrote:Aren't these sensors placed between the pump and the injector?Holm86 wrote:And why is it a pulse flow?? I would think the flow is pretty smooth and constant.
Holm86 wrote:This has also been discussed here before. And yes i do think that most of us believe this is the way to go.langwadt wrote:has anyone considered putting the mgu-h in between the turbine and compressor?
As far as I recall the previous discussions one sensor is going to be after the feed pump as you say but also there are going to be a sensors before the injectors. But I may remember it wrong or the regulations changed since then.Holm86 wrote:There is a feed pump, a high pressure pump and then the injector. The sensor is placed in the tank after the feed pump.
The flow from the feed pump to the high pressure pump is pretty constant and even. Not pulsating.
