Some years ago I did a model that took into account shims and areas and was not close to reality.
In pages 200 and 201 of the shock absorber handbook (2nd ed) you will see why.
Not here, however.JACKHOLE wrote:Dave, I am Having a hard time wrapping my head around this wondering if you could explain a little more or an example. I haven't heard of this before.DaveW in What the 'Fric' is it wrote:The rear is locked initially. When it finally starts to move the apparent friction falls, suggested that once the friction is overcome, it takes time for it to reset. The characteristic is reminiscent of a pre-loaded shim valve (which requires time for the fluid boundary layer to be ejected after the valve closes, during which time it still leaks fluid).
I know its a little off topic.
Apologies, I'm not familiar with TRD's. If they are what I think they are, then there is much information already posted in this thread. See here, or here, for example. (Apologies, Wil).Luke wrote: .. I have been thinking about hysteresis and trying to understand why on TRDs quite often the Compression open forces exceed the compression closed forces unlike on non TRDs.
Thanks for the replies people. Sorry I am a bit unclear as I can't post an FV plot. A prime example is on page 32 of this:WilO wrote:Certainly no reason to apologize to me, Dave. I owe Luke an apology, if anything, for posting incorrect information.
My thought was that a through-rod damper might exhibit hysteresis due to the necessity of having greater sealing forces and associated friction, and that the friction force might be greater in one direction than the other.
Thanks for the correction Dave.
Apologies, now I understand. TRD = Through Rod Damper. There is still much information posted in this thread, though some of the diagrams are now missing, unfortunately (come back 747heavy). You might start looking here.Luke wrote:....you will see the lines "cross over" on most TRD graphs. I see it mainly on the compression side, but this also can occur on the rebound side as displayed here...
DaveW wrote:Apologies, now I understand. TRD = Through Rod Damper. There is still much information posted in this thread, though some of the diagrams are now missing, unfortunately (come back 747heavy). You might start looking here.Luke wrote:....you will see the lines "cross over" on most TRD graphs. I see it mainly on the compression side, but this also can occur on the rebound side as displayed here...
Ohlins TTX are very good dampers, probably only improved by Multimatic's DSSV (showing my prejudice). The only issue with the TTX (in my view) is that the low-speed controls are often too powerful, so low speed settings should be adjusted with care.
Damper velocity trajectories can usually be modelled quite accurately with a pure damper operating through a series spring. The series spring is often different (slightly) compression to rebound. A 40mm TTX typically has series spring value of around 4.5KN/mm. It is the result of oil compliance (with dissolved air). The "shape" of the hysteresis loops (as shown in Figure 11.0 of your reference) is (mainly) the product of the shape of the pure damper distorted by the series spring.
Interestingly, the series spring stiffness of a TTX sometimes appears higher than my estimates, possibly because of valve dynamics (a valve time delay appears as negative hysteresis). On one occasion I "corrected" a TTX trajectory by removing a time delay of 2.5 milliseconds (I recall). Perhaps this is the cause of your complaint.
First, I don't think the dyno trajectories indicate cavitation (but that can always be checked by increasing charge pressure), but they do suggest to me that a better comprise might be obtained if you feel the need to increase compression damping.JeffHNY wrote:Without any data to fall back on is this considered a normal amount of hysteresis or would it be considered excessive for a new damper? From reading through this thread it looks like there may be cavitation occurring.
Compression biased damping is generally a good idea.JeffHNY wrote:Also for another vehicle I can see myself going with a ratio favoring more low speed compression but as DaveW mentioned the design may not be conducive to this. Any tips on how to improve damper performance?
