Hail22 wrote:I'll be interested to see what style rear wing / pylons with monkey seat Ferrari will use.
I'm still wondering whether there may be a loophole with the exhaust exit by simply cutting a slit at the leading top edge of the exhaust housing to allow some hot gases to be blown into a tube feeding into the central wing pylons hitting either under the rear wing scoop or feeding to the floor.
What do you guys think, I cannot seem to locate the regulation pertaining to the new 2014 Exhaust housing / exit, then again I've been quite time poor in recent weeks!
Regards,
5.8.2 Engine exhaust systems must have only a single tailpipe exit which must be rearward facing
and through which all exhaust gases must pass.
5.8.3 The cross-sectional area of the exhaust exit at the rearmost point of the tailpipe must lie
between 7500mm and 14000mm.
5.8.4 The last 150mm of any tailpipe must in its entirety :
a) Form a thin-walled unobstructed right circular cylinder with its axis +/- 5° to the car
centre line when viewed from above the car and between 0° and 5° (tail up) to the
reference plane when viewed from the side of the car. The entire circumference of the
exit should lie on a single plane normal to the tailpipe axis and be located at the
rearmost extremity of the last 150mm of the tailpipe.
b) Be located between 350mm and 550mm above the reference plane.
c) Be located no more than 100mm from the car centre line.
d) Be positioned in order that the entire circumference of the exit of the tailpipe lies
between two vertical planes normal to the car centre line and which lie between
170mm and 185mm rearward of the rear wheel centre line.
5.8.5 There must be no bodywork lying within a right circular cylinder which :
a) Shares a common axis with that of the last 150mm of the tailpipe.
b) Has a diameter 30mm greater than the tailpipe.
c) Starts at the exit of the tailpipe and extends rearwards as far as a point 600mm behind
