beelsebob wrote:Blanchimont wrote:And how do these pylons fulfill the single section rule from the regulations?
"3.7.8
Only a single section, which must be open, may be contained within any longitudinal vertical cross section taken parallel to the car centre line forward of a point 150mm ahead of the front wheel centre line, less than 250mm from the car centre line and more than 125mm above the reference plane."
How do they not? What makes up the second cross section?
To be more precise, it's about a single open section.
The FIA says:
"1.20 Open and closed sections :
A section will be considered closed if it is fully complete within the dimensioned boundary to which it is referenced, if it is not it will be considered open."
At the line in red in the picture it could be that the section is closed, but probably i'm wrong and it just looks like that.
Dear FIA, if you read this, please pm me for a redesign of the Technical Regulations to avoid finger nose shapes for 2016! :-)
