Red Bull RB10 Renault
Huntresa
Huntresa
Re: Red Bull RB10 Renault
Doesnt look like an s-duct, it looks like the nose is connected via the splitnose to one of those that mclaren used before.
AnthonyG
38
oetger wrote:http://www.imgdumper.nl/uploads7/52e763 ... image1.jpg
Looks like they use hot air from the radiator to "blow" the diffuser.
Or they shaped the 8th gear like a fan so it's sucking the car into the ground. :mrgreen:
seahawk
Sleek design, interesting tail details.
raymondu999
Is it just me or does the engine lump look bigger than other engines
失败者找理由,成功者找方法
gandharva
gandharva
252
The rearwing is still so tiny...
infy
infy
Do you perhaps think that the tip of the nose is one of those turning camera's they tested last year?
Crabbia
Crabbia
raymondu999 wrote:Is it just me or does the engine lump look bigger than other engines
its not just you. Look at the "b teams" for comparison too. RB10 hides it better, because of better design. Compare the sauber and FI to the STR.
engine hump is very visible on STR though because of sloped down sidepods.
then the issue is even more evident.
A wise man once told me you cant polish a turd...
hotochan
hotochan
so much 'nothingness' under the rear wing where other teams put aero stuff en masse.
vall
vall
so, it looks like Ferrari has the lowest nose of all. I hope someone will soon do the car comparison image ;-)
raymondu999
What I meant is - it looks like the Red Bull has a fatter coke bottle, whether due to engine packaging requirements or otherwise.
失败者找理由,成功者找方法
Kiril Varbanov
147
It would have looked awesome without the mandatory chin... Why, FIA, why?
.poz
.poz
51
Re: Red Bull RB10 Pre-launch Speculation
Vanja #66 wrote:
slimfitcasual wrote:No camera pods?
Great spot...
There is something on the bodywork behind the suspension arm.. can be for camera ?
astracrazy
astracrazy
31
is that a s-duct on the nose? Exit looks covered by the total badge - looks raised
n_anirudh
n_anirudh
yes, its a reverse duct..
Huntresa
Huntresa
So what do we think about this splitter concept on this nose ?
