Or they shaped the 8th gear like a fan so it's sucking the car into the ground.oetger wrote:http://www.imgdumper.nl/uploads7/52e763 ... image1.jpg
Looks like they use hot air from the radiator to "blow" the diffuser.
its not just you. Look at the "b teams" for comparison too. RB10 hides it better, because of better design. Compare the sauber and FI to the STR.raymondu999 wrote:Is it just me or does the engine lump look bigger than other engines
What I meant is - it looks like the Red Bull has a fatter coke bottle, whether due to engine packaging requirements or otherwise.Crabbia wrote:its not just you. Look at the "b teams" for comparison too. RB10 hides it better, because of better design. Compare the sauber and FI to the STR.raymondu999 wrote:Is it just me or does the engine lump look bigger than other engines
engine hump is very visible on STR though because of sloped down sidepods.
then the issue is even more evident.
There is something on the bodywork behind the suspension arm.. can be for camera ?Vanja #66 wrote:Great spot...slimfitcasual wrote:No camera pods?
