counter intelligence!ecapox wrote:I wonder why they use the neon free flow vis, which details out exactly what is happening, while other teams use the UV flow vis which isn't quite as bright and obvious to prying eyes? Not that we can't see what's happening in each scenario, but one is way more visible to journalists and prying eyes from other teams.
No, they'll be keeping the throttles open as far as they can and using the turbo unit to harvest energy, hence the 'hot blowing' type noise.e30ernest wrote: Could they be using a combination of both therefore creating that sound off throttle?
http://www.omnicorse.it/magazine/34257/ ... ci-nel-runshotzski wrote:Of the 97 laps Nico did, how many tyre change, and compounds did they use? Do we have a data on that? Interesting drivers weren't complaining about tyre performance
I get your point. As i look closer i believe that this is just a change in camber. the car itself seems to stay horizontal while the wheels are angled. Maybe they improved the suspension in a way that keeps the car aero stable but now also helps the tires in an innovative way.FoxHound wrote:In pictures 5 and 6 that forza kindly posted, you can clearly see the car leaning through the corners.
I have not seen this behaviour as pronounced as I have on the mercedes lineage starting with the W02.
